Yes, it’s spring-loaded. The cable itself is also stiff, which helps to push it back in place.
I just dont get one thing… As l understand there is a rotor and 4 pins in the distributor. The rotor rotates at half the engines rpm and each time the rotor comes close to the pin the spark jumps from the rotor to the pin and then to the spark plug. I know some rotors are made much like a clutch on a chainsaw. As the rpm rize the centrifugal force sets the timing. I alsow know some of the older distributors had a vacuum regulator to set the timing but on mine it is just a fixed rotor and fixed pins. How does the timing set on this sort of distributors when the rpm rise?
For what its worth, I looked at a Seat Arosa forum and found the following in a thread on how to set the initial timing:
You need a special tool VAG1551 which connects to the vehicle and locks out the ecu from automatically advancing and retarding the timing.
Once it is locked out you can then set the timing using a strobe light.
But since my distributor is already set for gasoline culd l not just rotate it aditional 10* (giveing me aditional 20* of advance on the engine due to the distributor being half the engines rpm)? I do not have a strobe light…
Am I correct in guessing that the distributor only turns at half the RPMs of the engine because the distributor only needs to send a spark every other revolution of the engine (only on compression strokes, but not on exhaust strokes)?
Hi, Brian!
12.2.2016
Correct guessing ratio per one single cylinder!
Crankshaft 2:1 camshaft. Camshaft 1:1 distributor.
In a 4-cycle 4-cylinder motor, the two (parallel) center cranks are 180 degrees to the two (parallel) end cranks.
That means that for every 180 degree of crankshaft turn two pistons are near the top center, and
one of them is near ending its compression stroke.
The other one is finishing its exhaust stroke.
During the 180 degree compression stroke on the crankshaft, the camshaft and consequently the distributor has turned 90 degrees.
That is just the 90 degrees from one peg to the next peg on the distributor cap!
Kristijan; I finally figured out what kind of a car you are working with. I love it and think it would be a good woodgas / charcoal gas vehicle.
Back to the distributor. We DID have vacuum advances on older cars— when you opened the throttle the vacuum in the intake manifold dropped and that vacuum drop changed the timing.
We DID have centrifugal force advance where as the speed of the distributor shaft sped up, the weights would swing out and change the timing.
NOW you have a computer that READS vacuum, and ENGINE RPM and it slows down or increases the spark. There is NO actual moving advance mechanisms in the distributor, The computer fires the spark at just the right time based on temperature, vacuum RPM and others… Having said that, I would just go ahead and build your charcoal gasifier and wait and see what the computer does to correct for charcoal gas. You might have to do something with the MASS AIR FLOW sensor if it has one. ( not on all cars )TomC
PS Looking back at your distributor, I don’t see any slotted holes that could be used to adjust the timing. I’m sort of thinking you drop that distributor in at the proper point and the computer takes it from there. Haven’t ever had on like that, but that is what I think I see in the picture.
I would go ahead hook up a cable. You’ve already notice a difference when turning the dist, so I think you’re good to go. The degrees of advance your are aiming for are 20* on the dist though (40* on the crank). With a cable you can adjust it on the fly to where ever you get the most power.
But since you already reached speeds near 100 km/h you can probably only expect just a tiny bit extra from that little 1 L, 37 kW (50 hp) engine.
Watch out for red hot exhaust pipes without timing advance. You might risk damaging your exhaust valves.
Anyone, please! I’m starting to doubt my own statement.
We usually talk about timing advance in “dist-degrees”, don’t we???
Good morning JO.
I am usually thinking of the crank angles when I mention degrees of timing advance or retard.
Hope all is well and you are warm on your side of the pond this morning .
Thank you Wayne, for clarefying. One never stops learning.
And thank you, we’re all warm and well. It’s snowing outside, but the coals are glowing inside
When ever I get depressed of dark and cold weather I watch some sunny Alabama wood pile pictures. They cheer me up
Hi, JO!
12.2.2016
Confirming. Stroboscope timing is always read on the flywheel or on a front-end crankshaft pulley.
Thanks Max. I just got confused wether those marks where to represent cam or crank degrees. I’ve always just read them and never thought about what they actually mean.
So the project Seat Arosa 1.0 is near its completion! I will let pictures do the talking:
the cyclone and radiator
cyclone and filter positioned in the spare tyre compartment
the generator (still thinking how to name it
the connections
the sack type filter
All thats missing now is a generator ignition system (the spark plug on pic no 5) and the engine tyming control. Hope you like it
Hi Kristijan,
Please do remember to protect yourself.
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Acarbon%20monoxide%20detector
Kristijan,
This so much fun watching your progress. I wish we were neighbors. Please explain your generator ignition system. Do you plan to squirt gasoline into your air inlet and ignite with the spark plug?
What particle size does your sack filter catch? Is this your only filter? I know you are using charcoal, but I recommend filling the pipe with stainless steel scouring pads to serve as coalescers of any tars that may be suspended in the gas stream. You may also want to add a safety filter of about 200 or 250 mesh that will clog and stop the engine instead of gumming up internal parts requiring a tear down.
Hello, Kristijan!
If you give the production year and model of your Seat, I can check through the sparepart list for ignition parts at the MOTONET and BILTEMA sparepart store chains in Finland…
The question at hand: Is the timing “switch” in the distributor, or is it connected to the camshaft?
If it is in the distributor, then the turning of the distributor “body” gives change in fundamental timing setting.
If it is attatched to the camshaft (end) the “switch” has to be turned relative to the camshaft…
Let’s see what can be found…
GREAT!!! Kristijan I can’t really say how impressed I am with your build. First off I like the little car as I have said before. Very impressed that you did this and did not give up any seating. Man!!! Then the charcoal gasifier it’s self It is SO full of basic new engineering, that had you told us all of your plans at the beginning, I for on and I am sure others, would have said you are taking on too many unproven methods. The danger being if any one idea doesn’t work the entire thing can be a failure. Any way, you have had limited tests and most everything is good so all I can do now is go back and observe and digest. First look at the pictures brought up many questions that required me to go all the way back to your first post and scroll back and forth. ( I think I wore out the middle wheel on my mouse). Absolutely a wonderful job and I am waiting for a video of a walk around and a go down the roadTomC
On your cyclone/radiator how do you clean out the cyclone? Or did I miss something
