Brian,
My buddy is a welder/fabricator that use a TIG torch every day… | suggested we use a terraccota clay pot that comes already with a 1-inch center hole on the bottom. The top of the tig cup would be flush – or sticking slightly above flush – with a couple mm if spacing in between. The idea was to protect the tig cup from a 55lb barrel of charcoal crashing down. Also, the concave structure of the vitrified clay pot would reflect and insulate the heat… much like firebrick. The heat would get reflected back into the combustion/reduction zone to help with efficiency, and to keep the combustion zone at a minimum of 1500 C.
But after this plane, he said all that wasn’t needed. a bag of char crashing down would do nothing… He’s said they’re super tough… In fact, he’s dropped his welding gun – tip and all – and landed on the cups, and they didn’t break. He said they do break from a 4 foot fall on concrete, but only rarely. Needless to say, we’re stoked about using these, and will report back with data. We anticipate a lot of testing, reporting, tweaking, and testing again…
At this point, I will not use the pot. I might eventually get to that point in the future, but i want to start with the simplest system, and only enhance components of the system when it aids in total thermal integration, and made from readily-available, off-the-shelf parts. Ultimately, I need to find resonance with efficiency, affordability, availability, simplicity, and utility. I really like the direction Koen is taking his journey, and along with Gary, are two very influential and inspiring people.
We’re going to start with some open-source plans of a very simple, efficient, and available… Affordability is relative, but we think under $700, and that’s if you pay retail, and didn’t cherry pick deals on Craigslist
Google SketchUp drawing coming…
Troy
