2001 Dodge Power Ram 2500 extended cab Pickup Truck V10
I am selling my 2001 Dodge Ram 2500 4X4 heavy duty truck. It has the 8.0 Lt V10 engine with the heavy duty driveline that only came on the Diesel and V10 trucks. It was originally from Texas and has been oiled by Crown since I brought it to Ontario. It has the typical rust starting to form on the bottom of the doors, but very easily fixed, and the back corners of the cab these are known for. Dana 70 rear with Posi trac, Dana 60 front with limited slip. Most of these trucks were made with 4.10:1 gear ratios which made the engine rev high on the highway,. This truck has 3.55:1 so it runs slow on the highway. When towing I just take it out of overdrive and it pulls like a mule. I pulled my 25Ft cruiser to Florida at 70 MPH with OD and cruise. Truck has the tow package with electric brake controller, HD transmission cooler and lots of other heavy duty equipment. The topper seals perfectly to keep the water out. Wheel well flares all around. There is some rust on the bottom of the tailgate but I am including a perfect tailgate I purchased for it that was removed from a new truck for a fifth wheel trailer hitch and stored indoors. I was in the midst of fixing every little thing on this truck to keep it for a few more years when I purchased a 2 wheel drive 2500 so I do not need this one. I winter in Florida so do not need a 4X4. I put in a new battery, starter, all new rotors, calipers, front brakes, rear brakes, new headlight lenses, all new cooling hoses, plugs, wires, ignition coils, filters etc. We had the transfer case removed and all new seals put in it. New shift solenoids in the transmission so it shifts like new. New Michelins in front have about 6000 KMs and the rear tires have about 10K on them. Emission tested in May. The hood is currently in the paint shop being repainted as it was the only part that was fading. Truck is stored in the barn since June as I do not drive it now. $6850. This is an amazing truck for power and traction. It is near Long Point Beach, southern Ontario but I will also deliver it to Sudbury or North Bay area for an extra $300 if paid in full.
