Deals On Wheels 2
Chris thank you !I’m glad too ! You and Wayne made a huge job!
https://washingtondc.craigslist.org/nva/pts/5245201769.html
Dodge v10 motor - $400 (Midland)
Includes Motor, heads, intake, timing chain cover, flywheel, front bracket, and ECM and motor harness for a 94 Dodge Ram
$400 OBO or trade let me no what you got
Does not run won’t turn over
http://cranbrook.craigslist.ca/cto/5206304254.html
2001 Dodge Ram 2500 SLT SB V10 4x4 Extended Cab PU - NEEDS REBUILD - $1599 (Grand Forks)
Running and insured but needs rebuild. V10 Engine runs rough - low oil pressure.
Play Youtube video to hear running: https://youtu.be/JjJJebXN8GU
  • Some body damage, very little rust
  • Always passed Aircare
http://detroit.craigslist.org/okl/cto/5245794970.html
1995 Dodge Ram 2500 V10 - $1500 (Lake Orion)
1995 Dodge Ram 2500 4x2 V10. 126000 miles. Good trans, brakes and tires. Runs and Drives. will get you where you need to go. I love my truck but it is time for it to go to a new home. See reply for contact information.
http://louisville.craigslist.org/cto/5246774089.html
2500HD V10 Dodge Ram 4x4 - $3200 (Greensburg KY)
1995 dodge ram 2500
condition: good
cylinders: 10 cylinders
drive: 4wd
fuel: gas
odometer: 131800
paint color: red
title status: clean
transmission: automatic
type: truck
Red 1995 2500HD V10 Dodge Ram 4x4. Runs great, cold air, good tires - less than 5000 miles, great power for pulling, regular cab, long bed. Body wear due to age. 131800 miles. Clean title.
2001 Dodge Power Ram 2500 extended cab Pickup Truck V10
I am selling my 2001 Dodge Ram 2500 4X4 heavy duty truck. It has the 8.0 Lt V10 engine with the heavy duty driveline that only came on the Diesel and V10 trucks. It was originally from Texas and has been oiled by Crown since I brought it to Ontario. It has the typical rust starting to form on the bottom of the doors, but very easily fixed, and the back corners of the cab these are known for. Dana 70 rear with Posi trac, Dana 60 front with limited slip. Most of these trucks were made with 4.10:1 gear ratios which made the engine rev high on the highway,. This truck has 3.55:1 so it runs slow on the highway. When towing I just take it out of overdrive and it pulls like a mule. I pulled my 25Ft cruiser to Florida at 70 MPH with OD and cruise. Truck has the tow package with electric brake controller, HD transmission cooler and lots of other heavy duty equipment. The topper seals perfectly to keep the water out. Wheel well flares all around. There is some rust on the bottom of the tailgate but I am including a perfect tailgate I purchased for it that was removed from a new truck for a fifth wheel trailer hitch and stored indoors. I was in the midst of fixing every little thing on this truck to keep it for a few more years when I purchased a 2 wheel drive 2500 so I do not need this one. I winter in Florida so do not need a 4X4. I put in a new battery, starter, all new rotors, calipers, front brakes, rear brakes, new headlight lenses, all new cooling hoses, plugs, wires, ignition coils, filters etc. We had the transfer case removed and all new seals put in it. New shift solenoids in the transmission so it shifts like new. New Michelins in front have about 6000 KMs and the rear tires have about 10K on them. Emission tested in May. The hood is currently in the paint shop being repainted as it was the only part that was fading. Truck is stored in the barn since June as I do not drive it now. $6850. This is an amazing truck for power and traction. It is near Long Point Beach, southern Ontario but I will also deliver it to Sudbury or North Bay area for an extra $300 if paid in full.
V10 DODGE RAM PERFORMANCE PARTS
K&N Cold air intake 300
Air aid Throttle body spacer 100
Jet performance 25hp stage 2 chip 300
All in good shape
Makes a noticeable power and fuel mileage difference
Woodstock area
http://losangeles.craigslist.org/wst/cto/5250112318.html
99’ Dodge Ram 2500 V10 4X4 Gas Pickup Truck - $7000 (harbor City)
99’ Dodge Ram 2500 V10 4X4 Gas Pickup Truck, runs great
club Cab
Lg Bed W/Liner
175,445 Miles
clean Title
Current registration
cold AC
Recently Smogged
Nice Interior
$7k OBO
http://denver.craigslist.org/cto/5250073889.html
1996 Dodge Ram 2500 SLT V10 - $5600 (englewood)
1996 Dodge Ram 2500 SLT V10 8.0 2WD one of a kind up for sale with 150 k miles runs great no leaks the interior in great shape if you have any question call or text
https://sfbay.craigslist.org/sby/pts/5253589214.html
dodge pick up v10 motor - $300 (san jose downtown)
$ 300 each , have two 1996 v10 ( 488 ci ) engines and a wiring harness from one truck . both needs rebuilding or make one from the two on a freshen up . just engines no trannys . great odd looking engine for your hot rod , salt rod , pull truck , hauler , rat rod . will make some bodies dream come true . can be hot rodded with aftermarket parts or build your own mods , same design as the 5.9 magnums . it will bolt up to a cummings auto or stick .
http://denver.craigslist.org/cto/5253627680.html
Great running 2001 Dodge Ram 2500 V10 - $2200 (Loveland)
This truck is a great running vehicle. I used it two days ago to drive over 250 miles and it runs great even at 80+ miles an hour down the highway pulling a trailer this truck has no issues. There is a few cosmetic things on the truck but all in all it is a great truck. It is a 2 Wheel Drive truck but is good in the snow as long as you put a couple sandbags in the back. truck bluebooks for almost $7000 so this is a really good deal. Please call Joshua for more information or to take it on a test drive
show contact info
The motor has 90,000 on newly installed engine and I do have the documentation on that the truck has 220k showing on odometer.just put the toolbox back on as shown in the last picture which was taken today. won’t last at this price! 4-door. Seats 6!
I wish this dakota was closer to Alabama . I think I would buy it and don’t really need it .
http://www.autotrader.com/cars-for-sale/vehicledetails.xhtml?zip=35146&endYear=1996&vehicleStyleCodes=TRUCKS&modelCode1=DAKOTA&showcaseOwnerId=57259853&startYear=1994&makeCode1=DODGE&engineCodes=8CLDR&engineCode=8CLDR&searchRadius=500&showcaseListingId=413188110&mmt=[DODGE[DAKOTA[]][]]&listingId=392397515&Log=0
http://minneapolis.craigslist.org/ank/bfs/5277321319.html
1995 2500 Dodge Ram 4x4 v10 - $2800
Selling my 95 Dodge Ram. Truck is very dependable and a very good work truck. A lot of new parts, tires are 90% tread, has newer brakes on all four wheels, a new starter and alternator, water pump has been replaced and radiator, u joints and axle u joints have been replaced, front wheel bearings, and transmission was replaced one year ago. 4 wheel drive works great. It does have a boss plow mount and wiring harness installed, the plow is not included. Aluminum tool box and back rack with lights. Call or text for more information. Asking $2800 or best offer (Winter is coming).
http://sfbay.craigslist.org/eby/cto/5277504376.html
1998 dodge ram v10 tow package - $4800 (oakland east)
I have a 98 dodge ram with a v10 in it. It has a stock lift and tow package. Runs good with 160k miles. 5 speed stick. Clean title. Needs a little tlc. Please call me at
http://losangeles.craigslist.org/sfv/clo/5277206961.html
1996 Dodge Ram 2500 v10 lariat - $3500 (tarzana ca)
I have owned this dodge ram 2500 v10 since new. it is in really good shape. 104500 orig miles.
ac power windows extra cab. tow hitch brake controller.
everything works. very good condition
call gary for info
https://joplin.craigslist.org/cto/5278699286.html
v10 dodge ram 4×4 - $2000
96 ram 2500 V10 4×4 217000 miles. Needs front u joint and dash is cracked. Has new steering gear box, power steering pump, and water pump.
https://minneapolis.craigslist.org/dak/cto/5278905087.html
99 lifted dodge ram 2500 v10
I have a dodge ram slt lots of power lots of new parts remote start new plugs new wires new breaks new ball joints new radiator open to trades lifted truck or jeep
https://burlington.craigslist.org/pts/5279365316.html
1995 Dodge Ram V10 2500 part out - $1 (Central VT)
I am parting out a 1995 Dodge Ram V10 2500 4x4 regular cab long bed with automatic transmission.
At this time the truck just missing the doors.
I will Not be selling it as a whole…
Email or text if interested in parts only.
802-five9five 1nine8four
http://vancouver.craigslist.ca/van/cto/5279014790.html
1995 - $5000
Dodge Ram 4x4
Extend a cab
V10
240 000 k original
Mint condition
Brand new tires yokahoma
http://www.ksl.com/auto/listing/2493115
1996 Dodge Ram 3500 Laramie
Miles: 141,582
Taylorsville, UT
This is a great truck but I need to sell it to get Bills paid.
I am asking 6000.00 obo this vehicle is under mileaged for its age. It books at 7000.00 on kbb.com
This is a 96 dodge ram 3500 dual wheels and is for wheel drive. Here is what you get:
Cd player ( infinity audio system)
Tilt steering
Power windows
Power locks
Seats six people
Has tow package with brake control
V10 8 L engine
Has new tires as well as a new exhaust system
Rebuilt the front end 2 yrs ago.
This is the SLT LARA MIR PACKAGE
ALSO JUST REPLACED STEERING PUMP AS WELL AS SERPINTINE BELT.
…read more »
Specifications
Year: 1996
Make: Dodge
Model: Ram 3500
Trim: Laramie
Body: Truck
Mileage: 141,582
VIN: 3B7MF33W4TM1752P8
Title Type: Clean Title
Exterior Color: White
Interior Color: Gray
Transmission: Automatic
Liters: 8.0L
Cylinders: 10
