JO, was that Rabbit only front wheel drive? With that much weight in the back, I guess you would have to stay on good roads?
Don, FWD only. I moved the driverâs seat forward and bent over the steering wheel. The front tires just barely touched the ground
Fortunately mostly downhill until I reached the pavement
JO- you are too funny!
Thanks for the ride in the wood gas powed dakota. Every vidio you show builds our confidence in your wood gasifier designs. And the extra power the dakota trucks 318 that helps get up too speed much better power too weight ratio then most trucks.
Thanks for the ride Wayne and Lisa. You were pretty talkative this time. Didnât even have time for Lisa to sing or nuâthin. I love the throaty rumble of that V-8. Sounds better than my wimpy 4 cylinder S10.
Thanks for the ride, Lisa and Wayne. I could hear a sigh from Lisa half way into the video, but I can guarentee thereâs none from the DOW community.
When I was swapping the tb yesterday a guy stopped by and asked me if I could build him a gasifier. I told him no problem, but that he could probably not afford me teaching him how to use it.
I suggested to start reading, watching videos on DOW and get back to me in a year or two.
Wayne, you sure set the standard for the rest of us.
Thanks for the ride.
Great video Mr Wayne.
You show now what can be done the best.
One problem though Wayne and Chris Saenz . . . . no CC closed captions enable with this.
I tried from my end viewing on-site and as YouTube viewed. No success enabling CC.
I slow brain audio anymore and most of the English-as-a-second language international members will not be able to see/hear Waynes excellent instructive commentary.
And thank you very much Mz Lisa for your enduring patience with with your hubbyâs endeavors. Good to hear your smiling voice too.
Best Regards
Hi Wayne, I will take a long ride with you and Lisa any time. She does a great job on the camera. Thanks again for asking us all along.
Actually, I used to think that was the only cause also. But I have now been finding another one. We have switched almost completely to hardwood kiln dried maple and cherry with no bark cabinet factory scraps for fuel. very dry. After about 5000 miles my throttle plate will begin to stick. For a long time I thought it was making tar. Finally, when we opened it up to clean it, it appears to be some kind of chemical surface level oxidation or other corrosion of the aluminum housing around the throttle plate. No tar in sight. Wire wheel, carb cleaner, heat, scrub it down and clean up, polish and it goes another 5000 miles.
Now Wayne, that ainât quite true is it? A couple miles from the house only gets you close to the end of the driveway.
White spots in the soot? Looks like mold? If thatâs the case I have a theory of my own. Happened a lot with the Rabbit. Unsufficient cooling area. Not enough condensation catched prior to entering the tb. Wet woodgas - more oxidation. To the point where the throttle plate was thin enough to brake.
(Your rail flushing intervalls caught my attention the other day)
Thanks for another country drive on wood gas power, your wood gasifier plans have many great building designs. Good clean fuel compared too gasoline or diesel for sure. and the camera was clear for rainy weather.
Thatâs probably it. I notice it more when the hay filter gets a little too full or the low spots in the gas pipes get too full of water. They have 2 spots where they can form a trap and fill with downstream condensate. The gas probably then picks up some water vapor passing throughâŚand yes, I/we probably need to wash rails more often. We just use these trucks day after day and, too often, âdonât get to itâ. squeaky wheel syndrome I suppose. or maybe we should call it the sticky throttle syndrome.
Wayne, donât we all like good heaters
We DOW to do some chores at m-in-lawâs today - a 100 mile roundtrip.
A quick stop at the grocery store and then climbing 700 feet in elevation before we reached our destination.
That was a beautiful DOW to do some chores.
The second picture makes me want to crawl back into bed. Iâll wait for next summer. Summer went too fast this yearâ not really, I just didnât work hard enough. TomC
