Another nice, rainy, foggy, fall day in Pennsylvania.
More of a cooking type apple.
The deer really like them. Everything seemed to do good this year. Lots of fruit and nuts. Don’t know if that’s a sign of a bad winter this year or not.
I know, the cooler isn’t hooked up right but I only had 2 of the rubber couplers.
This setup run the generator for about 45 minutes but it wasn’t running at full power.
The jar caught about 2 ounces of dirty water with fine charcoal dust.
Then I checked the bigger filter with the rocks in it. It caught about 5 more ounces of the same dirty water. Very slight oil (rainbow) look on the surface but couldn’t notice any tar.
It did use a good bit of the charcoal and it seemed to be bridging a little after the 45 minute run. Again, better graded charcoal should help and the moisture was likely from the ashes and fine charcoal that I packed in around the brake rotors to seal them. At least that’s what I’m hoping and it will run better as everything dries out and gets settled in place.
This was what the underside of the felt out of the filter looked like. Probably another reason the generator was lacking power. The felt was damp and coated with the damp charcoal dust. Guess I should try to find some straw before trying this again.
Hopefully the cyclone will catch most of that dust once I get it done and the cooler should work a lot better when it gets hooked up right.
Still though, this new down draft gasifier looks like it could work. The fins on the outlet pipe dropped the temperature at least 30 or 40 degrees F. and the cooler helped a tiny bit but it was mostly all just going straight through the bottom pipe. The filter with the rocks dropped the temperature to around 100 degrees F. but I think the gas still had a lot of moisture in it.
I then ran the generator for a while on gasoline just in case.
This was the experiment while it was running on gasoline. Along with continuing to charge some cordless tool baterries, I hooked a small arc welder up to an old car battery. A couple of the cells were not bubbling as aggressively as the rest. I kept turning the power up and down but kept blowing the 13 Amp breaker on the generator if I turned it too high for too long.
I tested that battery after charging it from the welder and it read about 200 CCA. It should have been over twice that when new. I hooked it back up to my solar panels but not much power from them today. It probably won’t help enough but it wasn’t working before so the other choice is trade it in on a new battery or sell it as scrap. Either way, this experiment won’t lower its value and might make it usable for a little longer. That trick has worked before.
