I meant to add if you cut a new key you really added a lot of timing.
At about 1 deg per .006 you do the math lol.
You should get a timing light on there and see where you really are.
Also watch your head and exhaust gas temperature.
You may not hear the ping ( I have hearing loss ) but you will see the effects of too much timing as a drop in EG temp and increase in head temp.
There comes a point where the improvement drops off with more timing and you start to drop back.
But you won’t appreciate it until you careful plot this out in fuel burn and power output.
A point comes when you are causing pressure spikes that are doing harm to the internal parts even though your real power is higher than you were with retarded timing.
I am going out on limb since we don;t have any tables and test data, but 30 deg advanced is as much as I am comfortable with suggesting as a maximum.
That’s a .060 slice off a stock key and you have exceeded that by a lot.
One thing I noticed is you can never be sure where the starting point is.
Some clones are so out of the ball park they start life well under 20 ( for NOX maybe? or just sloppy tolerances I don’t know )
Need a timing light.
The ignitions on these engines are very very stable.
Once you have a found TDC and back marked your flywheel ( or pulley what ever you are using its easy to see even with cheap Chinese timing light )
This Clone is set at 25 before TDC and runs just under 10:1 compression on pump gas ( this is a stock GX200 with the flywheel and head off a 160. The 160 flywheel is broached for 25 with the stock key so its a bolt on trick for more timing. It burns 91 premium ).
Now see how easy that pull starts, you should be able to get to 25 and still pull start.
But if you increase compression you will need less timing.
Your looking at the grub screw holding the pulley.
Wayne:
I can not see what engine that is.
But its big block.
I know they share a lot of parts and a stock head from a stable mate may fit that block and it may give you a compression boost.
I know you can use a 390 head on the larger Chinese 420 and 440 motors and get a compression increase of about 10:1.
If I was going to rebuild a generator specific for Gen gas I would look real hard at that option.
10:1 is a magic number it still pull starts, timing requirements are less and stock internal parts still work as long as you do not over speed them
Very clean inside.
Could you take an even closer picture of the head and piston?
If you can buy a GX200 replacement cylnder head gasket that will give you a small compression increase if you plan on returning this engine to service.
How does the cylinder bore look?
I wonder how much wear you have ?
Inside the spark plug boot there is a brass threaded part that makes contact with the spark plug.
This unscrews and a small spring and button.
Remove this button and replace it with a small piece of welding rod or copper wire.
This is a RFI noise suppressor and removing it will allow more coil energy to snap across plug gap.
The GX200 has a very very short rod compared to the length of its stroke.
To compensate for this the wrist pin is offset slightly from the centre of the piston to reduce the amount of side force on the power stroke.
In a perfect world the Small block would have a deck about a three quarters of an inch taller, but it had to be a cube shape that fit where the flat heads were installed and the solution was this offset piston.
Wallace’s comment above explains the piston arrow marking.
So the offset piston pin is located to the correct side of the engine on assembly.
Piston will noise slap and have accelerated side skirt wear if put in 180 degrees wrong.
Sounds like you been talking to a fellow Syracuse NY…
Very reasonable way to go.
I draw file quite well.
You might want to consider set up a jig for the head to draw file it if you get uneven sanding ( one side higher than the other )
Prussian Blue, a mirror and Draw filling is my way.
Finnish with a strip off a belt sander.
But yes its slow and steady vice work.
Garry is a great fellow I know him from years back, but we never actually met and I would like to tip a glass with him someday.
We even discussed a Clone for producer gas years ago but I wasn’t really ready to build it.
Finish off with valve grinding compound on a piece of plate glass.I’ve been told that lapping the block this same way will allow you to eliminate the head gasket. A little aircraft grade gasket sealer supposedly does the trick if the head and block are lapped flat.
The head gasket most will use for this is about .010.
There needs to be about .030 to .040 bump space between the piston face and cylinder head.
I think using the head gasket would not hurt.
I do lap the heads as you suggest Bruce because I find it gives a head and block a finish that offers maximum grip in a head ( and I have been doing this since the mid 80s on Honda engines ).
As for a sealer if you use a clone or Honda Steel gasket they have a sealer applied to them already.
I find this works real well and most of the time you can reuse a Honda head gasket a few times without much worry on a mild engine.
Here is your typical coated steel gasket with sealer
The other one you see is the thicker GX160 head gasket.
It adds about .060 and will decrease the compression on a GX200.
There are some plane steel gaskets too.
Those I would spray with some sealer just to be safe ( I use some permatex head gasket sealer works well )
What is your intended generational RPM ?
You want your timing set for that range.
I build clones that turn 7000 rpm and manage just fine to run static timing even though its hobled by the propagation delay induced retard…
I have a hard timing understanding why you would need more range than the OEM Honda UT2 ignition can provide with an manually indexed flywheel set the intend RPM range.
