Hello Martin,
I can finally help someone out since I have most of the answers thanks to my own system; I have a permanent-magnet pico-turbine at home.
I’m not sure what regulates your 24V turbine, but in my case, the inverter settings handle it (I use the inverter’s wind turbine setting like Tone); an MPPT controller works too, but there is a slight drop in output.
Personally, if my batteries are full, a diversion circuit switches the turbines to a load resistor. It’s set to 320V, so if the turbine overspeeds and the voltage climbs too high, the diverter kicks in. I installed it as a safety measure, even though I was told I didn’t need one. I only have a 7-meter head, and with an inverter capable of handling three times the turbine’s output voltage, the inverter’s internal resistance compensates for the load.
Another solution is using a solenoid valve to shut off the water flow if it’s being fed through a pipe.
I recommend protecting your inverter with a fuse.
Feel free to ask questions.
I realize I didn’t mention this in the dedicated thread, but I’ll add some details there.
Martin, David made a few interesting suggestions for your case:
- if you replace the car alternator with a permanent-magnet motor from a washing machine, you get high voltage (230V) and the current is reduced tenfold; this motor is capable of generating 500W of power
- battery charging can be done with a “classic” charger, though an electronic charger—which automatically adjusts to the battery—is a better choice
- David also made a very interesting suggestion regarding a “water shut-off valve”… if I might add something: by using an electric actuator capable of continuously opening and closing the valve, you could actually control the generator’s power output and adjust it to the specific need—charging the battery.
@Marty , what type of turbine do you have a what are its parameters. Namely rotation speed.
I would say that best solution for such a small system to keep speed to power demand would be mechanical governor like for steam engine
Hi All
Yesterday my Wife treated us to a steam train excursion ride. I looked up the now various steam power topics here on the DOW to post up my pictures . . . No way do I want to reactivate one of those Dog-Bite-It’s-Own-Tail topics. So since this is the last full day of Northern Hemisphere Summer here are my Summer excursion trip pictures:
The first picture shows the small steam powered turbine electrical generator for the engine head light.
Ha! Ha! The Conductor had to stop dramatically punching on-board traveling tickets to jump off and chase free-range horses off of the tracks. The Engineer and Fireman by regulations; not allowed to leave the locomotive cab.
Thank you David, Tone and Kamil for your suggestions.
The turbine is a Pelton type spinning at about 1770 rpm when loaded, unloaded it will double that.
I looked further into rectifying the AC to DC and using a solar input, but that is apparently a no go. The volt/amp properties of solar is different from a generator and will confuse the MPPT electronics perhaps damaging it.
I don’t have an inverter yet, that is next on the list (along with batteries). I will have to see if the inverter I am considering has a wind input with a sufficiently high voltage capacity. The issue here as I see it is, what happens when the batteries are full. Will the inverter activate a dump load? But as David mentions, I could add a voltage sensitive diversion circuit rather easily.
Tone, since you are the reigning expert here on induction motors, what is the relationship between rpm and voltage for an induction motor driven off grid with capacitors supplying the excitation current? If I double the rpm will the voltage also double? With no grid, what properties of the motor determines its output voltage? The capacitor’s μF?
Thanks again for all the help guys.
With such a turbine, 3 phase asynchronous motor as generator is practicaly a MUST. 4 pole motor will have appropriate RPM around 1600, which is perfect match. If you do not need to care about water flow, the best way how to deal with load balancing is to use ECL at the home side. The shunt load for ECL might be e.g. electric water heater or other type of usefull resistive load.
Marty,
I could be totally off the point here, this is my opinion only!
I don’t know the state of auctions, yard sales, classified ads, scrap yards, surplus sales or bargain stores in your area. Myself, here in the states, I would be looking for deals and bargains on heavier conductors for your low voltage DC “transmission line”. As we know, power companies handle this problem by going to higher and higher voltages. This of course comes with a new set of problems: electrical safety, Insulation integrity, cost of supporting infrastructure, etc.
You probably want to direct bury this line, but what if you placed an above ground outdoor-rated junction box at appropriate distances, could run in conduit what wire you have and could obtain in a daisy chain up the hill to the charge controller, and have the system running at lower efficiency until you can upgrade the size of conductors, one link at a time, or even parallel smaller conductors together? Yes, a hodge podge. You will have to choose which problem to battle and compromise on efficiency Vs. practicality. All this three-phase talk gives me a headache, but I am learning from you all. I happen to be a big fan of permanent magnet DC motors / generators! ![]()
That was my feeling too. My biggest issue now seems to be the charge controller. The wind controllers all accept 3 phase power, but limit it to 48V max.
Me too. The generator on the turbine is a pm type. At one time I was considering upping the voltage with a transformer for transmission and then lowering it at the house. I have a damaged 30kw 3 phase transformer - one phase blown, the other two good. It was used to transform 23,000V to 240V. Since the generator is single phase, I could up the voltage with one coil and lower with another. That would leave me with 1,200v to send uphill. I’m not sure I could bury that and I really don’t want aerial lines (visual aesthetics and you should see what falls from all the trees during wind storms here). I think most wire here is rated for 600v.
Edit: And I’m not sure what the power losses would be using a 30kW transformer for a 0.5 kW load.
Try to check this source, @Marty .
I’ve never seen a train engine that looked anything like that.
Tone, I really want to wind a copper excitation winding onto the rotor of a three‑phase electric motor with a power output of 18.5 kW. And connect it either to the slip rings and brushes, or create a brushless excitation outside the generator, where the cooling fan used to be. Also, I plan to make two additional holes in the bearing shields to organize forced internal cooling of the electric generator and to heat water (via a heat exchanger) and to increase the electric generator’s power output to 20 kW without overheating the windings.
This scheme will allow (unlike permanent magnets on the rotor) to regulate the output voltage when the load on the generator changes. And the throttle regulator of the internal combustion engine will maintain a constant voltage frequency.
All this will make it possible to do away with chemical batteries, a powerful inverter, and chargers. All of this is still too expensive for my area. So expensive that the electricity generated does not justify the costs of regularly replacing the batteries.
Of course, operating an internal combustion engine, an electric generator, and a wood gas generator with an air‑boost turbine in continuous 24/7 mode will require solving some technical problems, but I’m quite optimistic:
The harvesting and chopping of firewood will be carried out using attachments for our future dump truck. The volume won’t be a problem — as long as it doesn’t hurt your back.
The service life of the internal combustion engine, the bearings of the electric generator, and the supercharger turbine will be extended by an autonomous lubrication system, a cooling system, and a system for preventing detonation, vibrations, and localized overheating. At least 5 years without major repairs. I hope.
The engine oil consumption of 200 liters per year will be addressed both by refining the used oil and by switching to locally grown vegetable oil and adjusting its characteristics to make it suitable for the engine and bearings.
All of this will make it possible to have electricity, heat, and fuel gas for heating appliances all year round, as well as motor fuel for travel.
Martin, here is my opinion regarding conductors and power transmission over a distance of 100–200 m for a power output of up to 1 kW:
If you properly ground the generator (which is not a problem when near running water), the earth can serve as one conductor with minimal loss—practically 0.1 V.
If you install a 3x1.5 mm² cable and use one 1.5 mm² conductor to transmit DC voltage of approx. 500 V, the losses on that conductor will be around 3 W, which is negligible.
If you use the remaining two conductors to regulate water flow, you can precisely maintain a constant 500 V; this can easily be done with your controller—you just need a reliable actuator, such as a Belimo. Another option is to use a motor equipped with a magnetic brake (motors of this type are used in elevators or lathes); this brake can also be controlled via the other two conductors.
I am not sure whether you are using a direct shaft connection or a belt drive for power transmission between the turbine and the generator. Why do I ask? An asynchronous (or synchronous) generator is a better choice if it operates at high speeds, as it requires less energy to maintain the magnetic field in the rotor. This is a textbook example of voltage induction in a conductor (coil), which depends on the rate of change and the strength of the magnetic field; consequently, a high-speed generator incurs half the losses. Regarding capacitor sizing:
If you use a three-phase motor with a rated power of 1.1 kW and a speed of 2900 rpm, three 10 µF capacitors connected in a star configuration are sufficient; however, for a motor of the same power but a lower speed of 1450 rpm, you would need to connect three 20 µF capacitors (or so I believe).
The output voltage depends heavily on the load and rotational speed; it rises sharply if there is no power consumption or if the speed increases.
The MPPT input, which accepts solar energy, can also accept energy from a generator without issues, provided the voltage isn’t too high; in any case, 0.5 kW is a low power level that, in my opinion, cannot damage the inverter input.
Martin,
Regarding the inverter, I recommend the same one that Tone, Joep, or I use.
The Deye inverter (depending on the model) can manage batteries, wind turbines, PV panels, a generator, the grid, and so on, all within a single unit.
I tested the 12kW model; one input handles 640W from my two Turgo turbines, while the other takes two strings of fifteen 410W panels. It works without any issues.
I’m no expert, but I can select the operating voltage on the inverter, couldn’t you do the same? Tone, do you know the answer?
Whether using MPPT or wind mode, there isn’t a huge difference in output, but wind mode allows for fine-tuning the settings to squeeze out a few extra watts.
The ideal voltage seems to be close to grid voltage, in my case, 230V to 240V, though that is what I had requested from the manufacturer.
Finally, regarding the turbine setup: there is a rectifier, a small capacitor, and a DC filter (I assume to handle interference). The turbine is grounded. Above all, don’t forget to protect the inverter with fuses.
Thanks for the info David. So the turbine generates 230VAC which is then rectified and filtered to DC and that is then input directly into the inverter? Then you have a diversion circuit that kicks in when the DC voltage exceeds 320V? Is that a separate piece of equipment, or is it in the inverter?
Thanks for all the info Tone. I wish I had your electrical knowledge.![]()
Hello Martin,
No, not exactly; it’s a three-phase alternator with DC rectification. And I could easily run it at 150V, depending on the inverter’s settings.
The diverter is a separate unit built using an Arduino; I didn’t program it myself. However, if the set voltage (which is adjustable) is exceeded, the power is diverted, in my case, to a resistor.
I’d like to continue the discussion on turbines by showing you some photos that illustrate things better. I just need to find them.
DonM. and TomH. that last picture I put up is of a logging railroad locomotive. These ran slowly on relatively small cross section temporary rails going up and in; then logs loaded out of twisty upper river drainages. So all drive wheels were mechanically driven. Yep. This one was highly unusual to me too. All I’d seen previously had a one side rigid fore and aft driving shaft external gear driving each wheel pair. These were Shay pattern locomotives. You can search up tons of pictures.
They had developed a rather large track section laying machine. It would lay down track sections ties and all ahead of itself. Logging operation done in that drainage; then remove the track sections on its way out for reuse on the next site operation.
All of these up in the woods steam operations had bigger/longer fire boxes to be fired by site cut and split woods. Not exactly “free” fuel. Labor intensive on site. Ha! Go out in the world, and solicits more woodsman immigrant workers. Versus city-boys and miners.
I keep cheering for these guys. This is the future of electric trucks, not the cyber dumpster.
Imagine this running on woodgas to recharge the batteries. All the torque and variable output handled by electric drive, fed by a woodgas engine running at a steady pull.
Hi Chris, what you wrote—a “wood-gas hybrid”—really changes the whole game for a car on the road. A four-wheel-drive vehicle is the ideal candidate for this: the rear axle remains conventionally driven via the transmission, while the front is connected to an electric motor that can function as either a generator or a drive motor. When driving downhill, the electric motor can provide regenerative braking to charge the batteries, while the main wood-gas engine runs under moderate load to keep the gasifier at operating temperature; during acceleration or uphill driving, the electric motor assists with the load, and short trips or city driving can be done on electric power alone. For my “Mazda” project, I want to incorporate a lower-power electric drive while retaining the “classic” wood-gas engine and transmission setup—so it doesn’t look like I’ve gone soft and started driving on electricity like “everyone else.” ![]()
Today, my son and I visited a man who has quite a few retired electric vehicles, and we brought home two electric motors. I plan to test the larger one (approx. 30 kW, 370 V) as a generator—in any case, they are very useful pieces of equipment…
