Life goes on - Summer 2026
Well, I’m not really sure if I should even mention this, but you all know how clumsy I can be.
I installed a pump between the tanks in the boiler room and did a test run, but it didn’t improve anything.
I wondered what the cause could be, and eventually decided to try some new thermometers—suddenly, the tanks showed the same temperature!
So, it turns out I installed that pump for absolutely no reason.
I bought a lambda gauge from Joom, but when the package arrived, it just contained a cheap, 5-gram plastic ring. It’ll be interesting to see if I can get a refund.
I’ve also been having issues with the car triggering an error for the mass airflow sensor, and the transmission has been shifting strangely. I ordered a new sensor online, but suspected there might be something else going on, too.
I replaced the safety switch on the gearbox, but that didn’t help.
I was sitting there thinking about it during my father-in-law’s memorial service yesterday, and it occurred to me that my OBD scanner can show live sensor data.
I tested it this morning and found that the mass airflow sensor was actually fine—it was the TPS (throttle position sensor) that had failed.
So now I have three perfectly good mass airflow sensors; things are going just great!
Ok. For killing some more time, here some to drool over. From our sunday walk in the woods near Tilburg.
Are those steel toed shoes? Im just curious whether that is the new stylish steel toed footwear. :slight_smile:
Not new, nor stylish but steel toed - yes :smile: Even though I think steel is replaced with some lightweight composite material nowdays.
Here in Slovenia, life goes on; autumn is turning cold. I sowed some wheat about a week ago—I hope it still manages to sprout. In recent years, winters have been quite mild, which makes early autumn sowing rather problematic: the grain grows too much, and then, when the cold and snow arrive, the crop flattens and turns yellow… well, I’ll see how it turns out. In any case, my wallet won’t be any lighter because of fuel costs.
Heavy clay soil, unploughed for about 10 years, on a slope—the Fergie can only pull a single furrow.
Thanks Tone, beautiful, Fergie still going strong! Nice weather, I saw snowy pictures from Bosnia this week. You got lucky. And your acres keep growing. Are you afraid that Fergie doesnt have a job?
I thought I would give an update on stuff going on here.
There has been an ongoing thing here this past month, a neverending spiral of stuff breaking and consuming time and money. Today I was going to move the old Fordson major tractor from one barn to the other so I can fit more stuff inside for winter, well it didn’t start so I charged the battery but not this time either. Thought it still was the battery since it’s old and also second hand so put jumper cables from a car on it, still not starting. Tried perhaps ten times but no real kick in it and started to smell smoke from the starter.
It probably is the field generating the heat (replaced the coals 15 years ago) which probably means that the bearings on the starter are worn (hopefully), my dad said that he probably made the bearings that are in there now. I do not remember that so either it was before I was around or it’s just my memory that is faulty.
There is a bit of play in the outer bearing, about 0,2mm and the inner bearing is probably way less worn so that will not be replaced now. It’s not that fun to get the rotor back in with holding back the four coals at the same time.
Luckily I found some bronze bearings with machined oil grooves in a drawer, have to make the inside for the axel bigger but the outside is correct plus I need to put two in there to get the width.
Will try this first and hope this fixes the problem, otherwise the rest needs to be taken apart to seek the problem.
All part of having old stuff I guess
Hi there Johan, i use a piece of thin copper wire to “snare” the brushes, stretched to hold them out when putting the armature back.
Then it’s just to cut the wire and pull out the loops.
This works with thin zip-ties also, around a match or tooth pick across the service opening.
Hey JohanM. the electric shop technique to set up the brushes for installation is to hook tool pull up and back on the flat coil spring; then lift up with a second hook tool on the copper lead, pulling the brush halfway out of the looped metal holder. Reset the spring nose against the side of the lifted brush wedging it up.
Another way is with the hooked tool lift the spring up and pull the brushes completely out of the holder, laying aside on their leads. Once armature installed; even end housing set in place; thenhook up the springs one at a time and reset the brushes down in place.
Watch you leads lay, imagining the brush worn down that the leads WILL be able to follow travel too and not hang up the brushes.
Regardfs
My wife recently got a call that if she wanted to see her aunt again, she better come quickly. We made a bee line to the east cost and had a nice visit. It is clear that her days on this Earth are coming to an end, but we got her singing and even in her current state, the Juilliard graduate has a much better voice than I could hope for.
However, the point of the post, on the way home we book a motel for the night. I didn’t want anything fancy, just someplace clean and cheap. Unfortunately, neither of my requests were met.
My neighbor for the night was a middle aged beat up looking guy carrying a single 40oz can of light beer, accompanied by a very attractive, very made up, much younger woman. As we passed, I said “Hello” and he grunted out a “Hey” while the girl looked at me and said, “I really like your shirt!” followed by a cute little giggle.
Drive on Wood T-shirts, spreading joy wherever they are worn.
I cannot remember how I replaced the brushes all those years ago but I think I tied something to them lightly and propped something under the springs against the housing tying the brushes to that.
All good tips from you guys, and to think ahead with the worn brushes too so the leads don’t stretch.
As I started filling you guys in on the starter, I will give you the continuation of it too.
The starter got taken apart for no reason, just on a whim and this is what was found.
As you can see there has been some arcs between one winding and the screw keeping it together. There were no bakelite pipes or some similar isolation around the screw so it has burnt a way through the winding insulation.
Some shellack flakes is dissolving in gasoline as I am typing, should probably been spirit but it is what it is now, starting work again tomorrow so it will get fixed further along but at least the problem is found.
Will probably put all three new (homemade) bearings in it anyway now that it is taken apart.
O.K. I will take the plunge. I will put up some of my long term now observations; concerns and goals here in this Summer or 2026. Some having a bit of snow on the ground now. Last series of wind and rain storms here; and all of the leaves are down now. This topic will soon go dormant; locked out. Replaced by Winter 2026.
This is the safest place for me to express these opinions as this topic is no ones; but for us all.
The revelation that the post WWII cheap available petroleum economies and lifestyles would be no longer be cheap; or so readily available, comes to us individually at different times. Some just waking up to this in the price/availability run-ups in this 2026. “Times are Changing”
For me poor-boy working class it was in the late 1960’s. Then the two availability and price shocks in the 1970’s.
Others waking up to this in later events timelines between these.
So . . . whatcha’ gonna’ do?? Pretty much for those who come to the DOW and stay our evolved lifestyles as we share them, reflect our responses.
Harvest wood. And make that as our energy base. Nurture trees replenishments.
Fortunately in America and Canada, and seems to be Sweden; there is the space as individuals to do this in places with the least interferences.
But absolutely you have to go smoke-less. Harvesting, you have to go as quiet as possible.
I home heat with wood smokeless. Not replacing the old now, gasoline chainsaws, but going corded electric, with some battery electric. Even manual, by hand, sawing some.
My making wood into electricity will be raw wood and only raw wood as it can also be done quietly and as much as possible smokeless.
Charcoaling cannot.
The most important to me of four reasons I reject charcoal systems. I’d start up a fire-storm here on the current now gone gaa-gaa charcoal biased DOW if I was to list out all of my valid no-charcoaling reasons. I just don’t read, or follow the charcoal topics anymore. Then I control. Then I do not react, care. Practice my Stoic indifference.
Back to raw wood.
Replenishing woods harvesting means you are not dependent on Urban wastes. You are not a dependent Scrounge. Not a dependent cockroach. Not a dependent parasite. In a living alive forest the gone dead wood belongs to the forest. The stumps and roots systems you leave in place as part of that share you left to the to keep a forest alive. The forest will share with you out to a maximum of 30% of growth. No more.
So yeah . . . I completely reject that now politically-correct notion that, “I only take the downed dead trees.” These do not belong to you. They belong first to the forest bugs; then to the small animals; the last to the forest soils. The other way is raping.
Ha! Ha! See? Long writing with no paragraph separations means most have by now tuned out.
The way to live as free as possible is to be quiet about it. Don’t be noisy. Don’t be smelly. Don’t be visually outstanding.
Hey AdminChris @Chris Seanz high time now to switch over to Life goes on - Winter 2026.
Regards to All - keep it smokeless - if free, stay free - if not free, get free
Unless you do it like this :grinning_face_with_smiling_eyes:
It depends Steve. Chile is a wood based culture, at least here in the south. Before they rebuilt the airport in Temuco (the gateway to Patagonia), they heated it with a wood stove. I thought it was so quaint. The post office still has a wood stove. People here are very used to wood smoke.
During winter the air in towns gets quite polluted. The government is pushing for people to use pellet stoves or at least dry wood in their wood stoves. The only time you have to worry about smoke is when burning slash if it is getting on towards dry weather. Lots of people have wood cook stoves and use them year round, so some smoke in summer is still acceptable.
But then, maybe we are the outlier, people who burn wood in other countries will have to deal with the issues you mention. I agree a big problem will be noise from gas engines. And lights at night. That implies you have something most others won’t have and they may come looking for it. So many people have solar arrays now, that the light may not be that much of a problem (hard to take a solar array), but a noisy engine will imply expensive gasoline/diesel/propane nearby.
The real problem we have here in Washington State is EPA government restriction they enforce on us.
With air quality. And then fire season that is also enforce in the summer time. It was not like this 20 years ago, but it is now. It is all about making us buy oil, gas, diesel, natural gas, propane, and oh yes let’s not forget electric. Greed, greed, and more greed.
Yes Bob. This meme pretty much sums up the U.S. now, and probably a bunch of other countries as well.
Good perspectives MartyS.
We hope there are still pockets around the world where everyday practical is still the normal.
Ha! Ha! Above I guess I had let two of my charcoal for engines reluctances out of the bag.
More clearly stated using charcoal as a fuel base allows raping off of every bit of live growths. Whole swaths of the earth bare and blowing away still from the discovery that sponge iron could be intense heats purified and even then melted mold poured into weapons. China. Old Europe. In the dry American west it was strip out the trees, even the stumps to smelt silver ore. These areas still have not fully recovered.
Almost any carbonaceous thing can be reduced to mostly just the carbons left. An apple. All foods. Then that, ground into powder and reformed into standardized carbon fuel pellets or fuel briquettes.
It is not that I hate wood charcoal. I use it as made in place every day now:
Well in for a penny; in for a pound . . . .
A third reason I do not support using wood charcoal for engines:
you are compromising your personal safety. Upgrading refining wood to charcoal makes it a denser compact long storage valuable. Like actual gold; honey; and alcohol.
I’ve had very little cut stacked wood stolen from me. Some when it was stored stacked out of sight. I stopped fine splitting and stacking and switched to big heavy half rounds initial stacking. Stopped the thefts shrinkage as it would require later sweat work then for a thief to use.
I’ve had 3 different full carry tool boxes stolen out of my vehicles in my 20’s They were the typical red painted metal tool boxes. Ha! I switched to dull muted colored fabric tool rolls for in vehicles tools. Or bags random stacked loaded up so heavy that no one could run away with them. Later in shops needing set up big tool boxes I would only set up with black and no name boxes. Let them become dusty and finger printed.
At home at the end of a dead end road, behind a 5 foot chain link yard fence; with 2-3 dogs inside I still allow my shop and tools area to go stacked randomized. With the five of the seven generators and the three chainsaws never clustered up; but spread out in the seeming madness jumble stacks. A jump-the-wire; cut-through-the-wall, hit and run thief can get one-two; but never get them all. Slowed down by finding them; and then the carrying. Distracted by the left right inside the door non-functional “interesting things” things left in plain sight. Squirrel logic. Here, there, and around. Never all in one basket.
Honey bee’s have no choice. It all must be in one place. A bear, a badger, a skunk will go for the liquid honey gold with no regards for the damage. The bees can recover. A wise human will only take as non-destructive as possible a percentage. Looking forwards to another year. And then another year after that. A greedy Human will strip out it all: royal jelly, bees wax . . . ALL. Then search out another hard working hive to pillage. Made and stored charcoal. A honey pot.
So yeah I have important reasons to me to really, really dislike this rush to “easy” just-use-charcoal.
Still one more reason left unexpressed. Not today.
Heating season is here, so I’m making pellet char in the wood stove. Damaged pellet bags are half off at HD. Here are pics of my latest retort. This one doesn’t roar and scare the wifey. I screen out the fines and use them in my Urine Diversion toilet in the cellar near my woodshop.
I have seen these toilets used in motor homes for dry camping no black water systems, only gray water tanks.
