Mike LaRosa .. Linden Wisconsin
HI MIKE L//what kind of flex pipe will work for gasifier,how do you know when the stuff is rigid enough.
Hi Kevin, I haven’t used the hose yet that Jeff gave me in Argos so can’t comment … It is plumbed in but on the Studebaker. The hose I used for years that Ted Carbone gave me in Kansas has held up well … It will collapse from suction on occasion but does a figure 8 and makes a pair of 2 inch piped at the restriction … I got one side of the rear end brakes of my black truck done today before the rain started … Hope to get the other side done tomorrow and flush and bleed the lines and start driving it again … Mike
Kevin, The hose that Ted gave me was black rubber and 4 inches in diameter … I have driven thousands of miles on it … I bet Bill S would know what it is normally used for … It had aluminum connectors … Ted got burned out on us and is in retirement but I talked with him a month or so ago … Mike
He is doing well …
Thanks Mike L I got some flex i may use temperarily on my elbows around the yard for testing, till i get other pieces .Good luck with your truck,I got more too fix on my old truck,i may have too go get another master cyleinder,if this one leak’s down on back brakes.fixed one back line today allso, hate working with brake fluid getting it on the hands.
Kevin, I got the rear brakes on the 93 chev done done today … The damn safety valve is still stuck up so I can’t bleed them properly yet … There is some fluid going to them … I tried tapping the plunger down but I will probably have to disconnect a front line and mash the brakes to get the juices to flow to the back the way they are supposed to … fun fun fun … The radiator for my cadillac is supposed to show up tomorrow … Next car project (no woodgas on that one) … Mike
Hi Mike L .Thats what i usualy have too do,unhook the front line at the master cycleinder,and or prime the master,then try getting fluid too the back.a fluid pump would be nicer,too load the back lines,i havent perchased one yet either.The back lines can be a pain at times,getting full psi.
It will eventually get that BB unstuck … The new wheel cylinders are full and bleed … I made a muffler for it today and got that on it … It was pretty loud and proud with open pipes … Mike
Kevin. I unhooked the front line the other day and it didn’t let loose … I have plenty of fluid at the rear brakes and they are bled. I pushed in on the plunger that is in the end under the rubber cover and it leaked some fluid there. I suspect the valve is defective… Usually I can nail the brakes for a while and get it to reset … I will probably just unplug the connector. I still want the light to remind me when I leave the e-brake on … I’ve been working on this German Cadillac … New radiator is in it and holding … Needs tires and a brake and fluid (trans and rear end) check next … At least there is NO, and I mean NO rust … I put 30 miles on it today and hopefully boiled the pure water out from around the spark plugs … Mike
HI MIKE L ,sounds like a neat car too drive, Good luck with your projects,I still got too get back too the rear brakes on my truck Too,drove it all winter with front brakes only, had too really slow down early, pita truck.A few more bugs too squash before winter, no ok i wont mention it, so i can stock up on heating and fuel fire wood.
Kevin, I think the proportioning valve is no good anymore … I disconnected the fake antilock brake stuff to run tests … I just hope some old friend will stop by and stomp on the brakes a few times so I can make sure they are fully bled … Hard to do by myself … Seems to work OK but ??? M
HI mike L, i am thinking i might have too change out the proportioning valve on my old truck,it seems like it may be half stuck, i pulled the one in the back that lets the brakes off when the truck is light in the rear.Good luck, i havent got back too reprimeing the brakes yet on this truck.I allways just prop a stick between the seat cushon and the brake pedal too get it primed, it works though it takes a while longer.I gess if we lived a little farther south we may have built a better brake primer by now.I still caint get over that idle control setup from the plans at drive on wood,nice effective ideas.
I keep an old shock that’s still good for bleeding brakes pump with your foot hold the brake down collapse the shock and stick it between the seat and brake pedal it holds and when you crack a line it extends If its a good shock.
Paul, That’s a GREAT idea !!! I have a brand new one in the truck … I usually just use a stick or the ice scraper … Thanks man, Mike
This is Ok high jacking mikes thread and getting pointers,i will try that shock idea too ,Thanks paul,and mike l
lost my entire reply !!! a battery rolled under my keyboard and I suppose the escape button went under other junk and it was all gone … F it … Put luggage rack and trailer hitch on new car … First time with plastic bumper … Need diodes in light wires for pigtail … More next time ??? Mike
I used a splitting maul to hold the pedal on the caddy …
Hi mike L i got my brakes slamming good when loaded,butt locks back wheels up when empty,i am thinking it was the rear brake hinge equalezor,as the springs hang low from the weight the brakes work better on 3/4 ton trucks,this one has stiff springs,so the equalizor needs put back in lines and i can try and adjust it.though it at least has good back brakes with the lines going around the unit.It may have been leaking past the hinge seal as the fluid was muddy after it started moveing too the bleaders better.
Warning … New car had LED’s for turn signals and flashers … I soldered diodes in lines and it just made them flash fast from the load of a real light bulb … The regular brake lights and night lights work fine as they are real incandescent bulbs (I had to replace one) … I will have to install some relays on this one to use a trailer behind it otherwise I will just have brake lights only … Beware … This is a 2000 and only 15 years old …
FUN FUN FUN … Busy till next week … Mike
Haveing fun and eliminating projects,power went out just as i was putting 3rd tranny in my truck, had too haul some metal too pay 25.00 on bank loan too stop the interst bang,late charge.Gotta get a second truck running down road,dont like the feeling of breaking down anymore.My s10 1985 is the canidate, 4.3 should pull my big truck home on dolly going back roads when needed.Good luck with transit never ending battle.
Kevin, I just junked out my 91 S-10 … Haven’t been paid for it yet but had to keep the young cop happy and get it out of here… I need to sho_t my neighbor … … The guy that took it has been pulling stuff off of it since … We’ll get it figured out. I can still see him sitting in a car seat with diaper rash before he could talk :o) … Mike … Time flies !!!
Scrap is so low around here at 70 a ton i hate yoo junk anything,i could have drove too saginaw too get 90 a ton,but the power and my phone was out and i hadent tested the tranny i just installed,bad luck,44 bucks for 1300 pounds of scrap,not worth the time,i am looking for another regular job soon,i should be good for few more working years,i got too get extra transit first,LATER
