A short report on the operation of the “new” gasifier:
  • the basic purpose of this construction was to be able to use wood of different sizes and shapes without any problems, which moves downwards without jamming or bridging, which ensures the same cross-section of the interior
  • a large cross-section of 50 cm entering the hot zone allows for a lot of power and low resistance
  • the lower central nozzle supplies air directly above the limiting opening, thus maintaining the active layer of charcoal until the end of the conversion, in this way all the charcoal is used until ash is formed, which simply retreats into the ash space with the gas flow
  • after a few years of using wood gas to power a tractor, I have found that all processes are endothermic and require energy to proceed, well, the temperatures are different
  • drying wood,… here it is necessary to heat and maintain the wood at a high temperature (150°C) in order for the moisture to evaporate from the interior, this process represents a consumption of approximately 5% of the energy of wood (wood with 15-20% moisture)
  • pyrolysis,… here the wood is exposed to a temperature of 200 to 500°C, relatively moist but very calorific gases are released, thermal decomposition of the wood occurs and charcoal is produced, which represents a consumption of approximately 4% of energy
  • the reduction of moist gases in charcoal “consumes” the most energy, this is estimated to be approximately 13%
A classic gasifier covers all these heat needs by burning wood, which represents more than 22% of the energy of the wood, the result is gas with a relatively low energy of approximately 1.5 kWh/pm.
If we include the heat recovery of wood gas in the calculation, it does not cover the energy for drying and pyrolysis, but when we add the energy of the exhaust gases, this is sufficient to cover these needs and also for preheating the cooled - dried gases that enter the reduction zone,… so here we can save 5% for drying, 4% for pyrolysis and we help the reduction process with 5% savings,… the gas becomes much more powerful and has at least 2 kWh/pm, an engine that runs on such gas reaches power and torque equivalent to diesel fuel
Tone, I totally admire your understanding of your system and the understandable way you can explain it. Your recent upgrades are admirable making your system one of the most efficient I have seen. Thank You.
TONE, WHY DID YOU CHOOSE TO BUILD A SELF-CONTAINED COOLING SYSTEM RATHER THAN USING THE TRACTOR’S ORIGINAL COOLING SYSTEM? :thinking:
THIERRY
Thierry, the first reason is that the thermostat layout and the hydraulic circuit of the tractor’s water pump do not allow for the very cold water from the lower radiator connection to be pushed through the condensation zone, this would have to be done with an additional pump for this system. So I decided to install a separate cooling system.
Mr. Tom suggested insulating the exhaust pipe, and I listened to him. Well, insulating this pipe will significantly contribute to ensuring that the exhaust gases enter the interior heating jacket at the highest possible temperature, because I want high temperatures in this part.
To install the insulation, I removed the gas pipe and lifted the hood, this is what the inside of the pipe looks like, … this is normal for me.
I just thought I’d add one picture, otherwise it has nothing to do with the gasifier, … Saturday work on the renovation of the stone crusher, … my friend Simon
The gasifier has completed more than 50 working hours according to the engine counter, well, that means at least 100 hours of operation according to the time per hour,…
Regarding the operation and efficiency of this gasifier, I can say (without the help of artificial intelligence):
  • I use different sizes and shapes of wood, including dust and bark fragments
  • I maintain a relatively high fuel level in the tank, when it decreases by the volume of one bag (50-60 l, or 12-15 kg), I fill it to the top
  • this filling is enough for 1-2 hours of work, depending on the weight of the work
  • the water-cooled condensation zone removes a lot of water, there is no water in the cooler, only fine ash, the filter is only slightly damp, there is no water to drain below
  • starting the gasifier takes longer than with the previous one (about 10 min), which is understandable due to the size of the hot zone
  • the operation is stable, at lower load and idle When the engine is running, the gas is of similar quality as in the previous gasifier, but under higher load, a very calorific gas with a lot of hydrogen and methane is produced, so that due to the high CR (1:12.5) of the engine, detonations occur, which I solve by increasing the proportion of air, with such gas, the CR of the engine should not exceed the limit of 1:10
  • let me also mention the “undesirable” effect of this gasifier, … due to the large expansion of pyrolysis gases after a higher load, overpressure is created in the gasifier, which prevents the entry of fresh air, so the charcoal below cools down after a while and the quality of the gas drops significantly, I eliminate this symptom by opening the “chimney”
    ,and the central lower nozzle lowered low above the restriction opening
Hi Tone
Is the area heated by the exhaust gases too large? Or could a bypass system divert some of the exhaust gases to limit excessive pyrolysis?
Is the height of the lower nozzle easily adjustable?
It’s really interesting that you shared your observations with us, thank you.
Thierry, I do not want to reduce this effect of heating with exhaust gases for the pyrolysis process and preheating the moist pyrolysis gases before entering the hot zone, because the wood gas thus produced is of extremely high quality, there are no problems during the operation of the engine with moderate or high load, if the engine operates for a long time with low load or at idle, there are also no problems, overpressure only occurs after a high load, when I suddenly reduce the load to a minimum (or the case of driving up a slope, then the road slopes steeply downwards and the engine brakes for a long time). For this case, I would need a robust fan that would suck out the excess pyrolysis gases and maintain a minimum negative pressure in the gasifier. This pyrolysis gas is very calorific, so it is a shame to throw it away, this gas would need to be burned and the hot zone heated with heat, in this way the symptoms of “hesitation” would probably be completely eliminated.
As you can see, the “development” of the wood gasifier is not yet complete, new ideas are coming about the design of a “good wood gasifier”.
About a week ago I decided to lower the compression ratio even further, it’s pretty easy with this engine, all you need to do is adjust the spacer and enlarge the combustion chamber… now the CR is about 1:12.
driving up a steep road, behind is a winch and a cart,… wood gas is an incredible fuel
Very satisfying woodgas grunt, Tone. Good " reactor-muffler" and camera. I’ve actually been DOWing window down today - to listen to the exhaust :smile:
OMG it’s green down your neck of the woods. Buds just started bursting here - a few weeks early.
Tone, your experience with wood gas and high compression engines is rare and helpful.
Most of us are converting spark/petrol engines with compression ratios that are lower than ideal for woodgas. There are ways to boost the compression ratio but (1) easy ways do not create much increase and (2) big increases require major surgery on the block and/or head.
Great to read about your experience taking a very high compression engine and tuning it down to improve performance. Most of what I read is that wood gas is so knock resistant that 16:1 is fine, even optimal, but those are research projects with every variable tightly controlled and optimized. Lower compression may trade off a little efficiency for a lot of practicality.
My list of woodgas engine tweaks:
(1) Higher compression (assuming an 8-9:1 donor engine)
(2) Earlier timing (to address slow flame speed)
(3) Two or more spark plugs per cylinder (again- flame speed)
(4) Well insulated gasifier to improve gas quality (more H2, less N2)
Woodgas is tricky because it has lower energy content vs petrol. To improve power, we could run higher RPMs since displacement of a given engine is fixed. More cycles per second means more fuel burned and more power.
But… the slow flame speed of woodgas leads to a drop off of efficiency as RPM increases. At faster RPM you may just be pumping half burned fuel. Earlier and more spark would help lift that ceiling a bit. Early spark through a timing bump is easy. More spark is harder- needs a custom or customized head.
AnthonyB. you left out one engine choice factor when using woodgas or charges . . .
just use a larger displacement engine for the true needed power output. This has been the classic engine solution still applicable today.
Two spark plugs are used in wide across, shallow depth combustion chambers primarily. Or as an emissions reduction in trying to keep the flame front off of the surfaces, more centered.
Woodgas though considered “slow” has very simple fuel molecules, more readably completely combusted. So more efficiently completely converted to heat and pressure.
The other engine design factors then dictates how well the made heat and pressure is converted into the rotary mechanical power you want.
The higher static compression heats and intensifies the combustion speed rate. So woodgas is then not so “slow”.
Good job Tone showing with your hillside living and working on slopes; true engine loading conditions. Flatlander’s have a hard time truly loading engines except at stunting accelerations; or at fast continuous highway speeds.
Ain’t no replacement for displacement: Can’t argue with you there, Steve!
My use case wants power a bit above what a simple lawn tractor v-twin can produce on woodgas/chargas. You can squeeze a bit more but it isn’t so easy- as you can see from my suggestions above. My next best idea is running two of the v-twins on two separate genheads and have the option of half production if one goes out or needs tending. Double the displacement, just spend twice- ha!.
You might be curious what I am trying to avoid? To me, the next step up is a salvaged 1-1.2L 4-cylinder car engine. I look at all the parts and cables and such hanging off the block in the ebay pictures and sense that it is beyond me.
I can do carbs and lifters and simple points/ECI. Modern car engines are an alphabet soup of EFI, ECU, MAF, variable valve timing… I’d be spending weeks taking complex things off the block, adding back simple and hoping it would still work in the end. If it does? likely can push 10kwatts through a genhead which would be amazing.
Hmm. How to relate my experiences with systems making 10kW/el without rabbit-holing Tones topic?
O.K. Anthony here.
IF your goal it a combined for space&domestic water heating woodgas electrical system (CHP) then you really, really want to go with a water cooled engine. The engine jacket water flow gives you the pumpabe off board heat transfer. Engine comes with it’s own water pump even.
Problem. Generator capable engines this size are MARINE and TELECOM; and are expensive. But at least you do get a directly coupled H.D. electrical generator head.
Use a watercooled take-out auto engine and once past all of the ignition electrical and fuel mixing problems you will find that engine relatively hard; and pieces expensive; to front end or rear end, couple up to a 10kW generator head. THEN you get to play around with electrical variable loading and sudden unloading speed control systems. Mechanical/vacuum, or electronic. More skull-sweating and expenses to pay out.
So a searched out USED marine water cooled generator system, or telecom as complete then will seem reasonable in comparison.
Now go back to that original CHP premise . . . an idealistic now IMHO from experiences.
Woodgas the #1 concern is having to feed the system wood chunks/chips sized and especially dried down that it will need.
Most fellows spend a whole lot of time, energy and efforts on the woodgas/engine/generators systems expecting they will sort out true fuelwood consumption needs later.
Nope. Nope. They at best - end up with a system that can, and does work, until they run out of summertime dried wood; or kiln dried mill scraps.
Now instead pretty much as Tone now does make the systems heats condition down year around as prepared fuel wood stocks, to be able to use year around.
That had became my “Ideal” by ~2012/13.
Then a more noisy, smelly, air-cooled engine become the way to go. To to cool itself; it must blow off external cylinder & crankcase, and even oil heats. Ha! Come with it own air blowing fan!
The easy to see examples of this all-heats-blowing-out concentrated focused, are the suitcase sized inverter-generator units. They are even focus blowing out engine exhaust heats too.
Drying down a one hooper load of prepared fuel wood stock just-in-time is very doable. It is in the maths. And wood will not complain about noise, vibration, or the smells of an air-cooled the way a SHMBO will.
Yep. Yep.
$4,000 for a Harbor Freight big single cylinder 9500 variable speed inverter-generator unit new.
$5,000 for a DuroMax V-twin 10/12,000 variable speed inverter-generator unit new.
But you do get an all in one package; variable speed and loading; all electronics safe system.
Sure derate and only then get an actual 6000-8000 watts.
If you really do insist on a full 10,000 that is where the investment in a reasonable battery bank and an inverter takes up the surge slack.
What you’s want anyway for overnights lights power; refrigeration to not have to be feeding continuously the woodgasifier beast system.
Space heating, and domestic hot water from wood is better done with its own separate dedicated system. My opinion? Nope. What the best of the best here are doing real, now, today.
Tone. J.O. Kristijan. And others.
Redundancy in systems is the pragmatic, safe way to go. Leave the Ideals, to Idealists. Be practical and pragmatic instead.
Friends, it is my pleasure to share my experience of using wood gas in an internal combustion engine. Now I can give the basic information quite reliably:
  • if the engine has a large volume of each cylinder (example like my Fergie 800 cc), the compression ratio 1:12 is the upper limit, similar to LPG or 100 octane gasoline
  • strong wood gas contains a lot of hydrogen and methane in addition to CO, so the auto-ignition temperature is somewhere around 550°C, if we calculate what temperature the engine reaches with CR 1:12 at the end of compression, ignoring heat losses and taking into account that the engine is heated to 80°C,… the result is interesting… 570°C, well in practice there is some heat loss during compression, probably about 100°C… anyway we are very close to detonation
  • engines with smaller cylinder volumes, with aluminum heads (which quickly dissipate heat), probably can withstand CR 1:13, well, engines , with a head made of gray cast iron, which dissipates heat from the surface more slowly, and should not have a CR higher than 1:12
    -I will not advertise wood gas, but now I can say that this is an excellent fuel for an internal combustion engine, the power and torque of the engine are quite close to diesel fuel
I will continue to think a little about optimizing the use of wood gas, … in previous posts I have already listed some of the characteristics of the operation of this wood gasifier, well, let me repeat:
-slightly slower start-up (large cross-section of the hot zone) … this does not pose a problem for me
  • possible use of various shapes and sizes of wood, there may also be dust and sawdust in between
  • produces strong gas, stable operation at low load or at high
  • it is unfavorable when after a high load it switches to low, then overpressure is created in the gasifier, which prevents fresh oxygen from entering the hot zone - the result is cooling of the glowing charcoal
Here I will list one of the ideas on how to eliminate this disadvantage.
If I were to monitor (measure) the vacuum in the gasifier, I could turn on the compressor (belt drive with motor, switched on via electromagnetic clutch) based on this measurement, this compressor would at the same time put some load on the motor and start sucking the wood gas out of the system after the filter. I would compress the gas into a cylinder to a pressure of 10-15 bar, if the volume of this cylinder were 100l, I could easily store 1-1.5 m3 of gas (2-3 kWh of energy) in it, which is already a nice supply of quality gas for an uninterrupted fast load on the motor.
I browsed the internet a bit about compressing wood gas, I was especially interested in what happens to CO, well, there is mention of the Boudouard reaction at temperatures above 400°C, where CO turns into CO2 and C ( Boudouard reaction - Wikipedia ) and the reaction with water vapor ( Water–gas shift reaction - Wikipedia )
Both examples of reactions would not take place if the gas were compressed to 10-15 bar, for which a single-stage compressor would be sufficient,…
Don’t mind, this is just a thought for now,… :slightly_smiling_face:
Sounds like an idea for evaluation. For the first sight, I see another big cylinder, compressor and wast amount of tinkering parts all around. Nothing for poor hobbist and many more things to fail.
Great minds think alike​:grinning_face_with_smiling_eyes:
Hmm.
I would trust both of you Tone, and Kristijan to play around compressing gases to fill tanks to 10bar (~1500 psi).
Most guys however will injure, or kill themselves; or someone else.
The two guys I’ve been involved with who did do woodgas compressing had no real appreciation for just how dangerous even 200 PSI can be with cobbled together; jury rigged systems compressing combustable gasses.
Twice I’ve walked away with a, so-long, “You all have good luck with that.”
Tone there is a real world phenomena where under actual working conditions an amazing “that is impossible” happens that the Lab/Math folks will not accept.
The first manmade occurrence of breaking the sound barrier is said to be the tip of a long leather woven whip tip. What? 3000 years ago.
Hard worked water cooled diesel engines often develop pin-hole pitting of their wet side cylinder liners. The percussive energy inside of the cylinder is energy transfer creating a micro steam bubble on the wet side cylinder surface. The bubble pops taking away each time, some cylinder metal with it.
Ships blade propellors suffer from a similar cavitation pitting.
So you propose a scroll or centripetal compressor system? Versus a piston compressor system?
Either way; somehow at an internal compressive boundary condition I think you will encounter a percentage of CO to CO2 & C’s (soots) reversion.
Just like I have seen on the back side of throttle body plates. “But that is impossible!”
