# Small engine mobile fuel station
**URL:** http://forum.driveonwood.com/t/small-engine-mobile-fuel-station/6368
**Created:** [February 21, 2022, 6:28am UTC](http://forum.driveonwood.com/t/small-engine-mobile-fuel-station/6368 "2022-02-21T06:28:00Z")
**Showing post:** 31
### Author: ![ForbiddenTuna](http://forum.driveonwood.com/user_avatar/forum.driveonwood.com/forbiddentuna/32/36469_2.png) [@ForbiddenTuna](http://forum.driveonwood.com/u/ForbiddenTuna)
#### Post date: [March 30, 2022, 11:50pm UTC](http://forum.driveonwood.com/t/small-engine-mobile-fuel-station/6368/31 "2022-03-30T23:50:51Z")
> [@Thrive Off Grid](http://forum.driveonwood.com/t/thrive-off-grid/2765/1496):
> So here is the updated nozzle assembly I am using now. Rather than bang a tap into the pipe that makes up the body and threading in the smaller pipe that makes up the nozzle. I now just cut a cross on the end of the body pipe and insert the nozzle. The tapered pipe thread then clamps the nozzle in place like a taper lock coupling. So if you have to remove the nozzle is will be very easy to do.
Here’s how he makes the new nozzles but with pictures. I’m terrible at describing things and need images.
If the 1/2" pipe is too thick, I would just hit it with the belt sander to reduce it.
I have this issue with all the 1/2" pipes I can buy they’re just a little too thick to fit in a 3/4" pipe
_[View the full topic](http://forum.driveonwood.com/t/small-engine-mobile-fuel-station/6368)._
