The "What followed me home" thread
if the output isn’t enough.. I ran into this video. (probably because I googled hho generators to see why I didn’t just get one..and it was price..)
He makes the plates out of graphite sheet, which i think is just graphite on fiberglass, but it is conductive and easy to cut and cheap. He is saying it is 3x the efficiency of I think the stainless steel plates.
Yesterday I brought a bunch of iron from the car service station of my youngest son’s godfather. 8 different motors, a balancing machine (there are 3 more left at the service station - they didn’t fit!), an indoor unit from the air conditioner, a bunch of all sorts of different pieces of hardware…
The most suitable and complete engine for wood gas is the VQ35HR from Infiniti, 3.5 liters of gasoline.
Unfortunately, there were no inline six‑cylinder engines as a gift…
The plan is to fix the motor together with the 20kW generator on a common frame so that the straps do not fly off. And put the frame itself through amortizing cushions on another, more powerful frame.
But first you need to change the cooling system and the engine lubrication system. And also run it on propane. Without all these modern bells and whistles in the form of camshaft phase shifters, poor thermostats, expansion tank caps that tend not to open at the right moment, and other very questionable modern solutions.
It is much more important to get a resource of at least 45,000 operating hours before the overhaul. And this is at an average speed of 50 km / h - it turns out 2.25 million kilometers. His timing chain is unlikely to last that long. And if it breaks, the piston group and valves will die…
VQ35HR. Photo from Inernet.
Hi All
I found a never-seen by me KISS saw at an Estate sale my wife took us to:
All of the one-person crosscut saws I ever seen were an actual 36" (91.5mm) working blade length.
This one is 42", over a full meter at, 107 cm. Sure caught my eye.
And that 42" is the length of my full arm torso twist stroking. I have long arms and wide shoulders.
Feels real good sawing with this tool. I found in the past that I can pull-work just as strong as I can push-punch out. This crosscut allows me to work/cut both ways.
It came even having been sharpen and tooth set sometime in the past.
Ha! Ha! On the “Alone” series of challenges the wife and I watch; a wooden boat builder fellow took one of these with him up on a live as long as you can to win $500,000 in the far North. Every one else took a Silky brand fold up saw or a break down bow saw.
I see now why he chose this. Smart man.
Hi SteveU, i thought i could share one of my cross-cut saws, (this one followed me home in july)
A 36 inch this one, we don’t have that big trees in Sweden, i still look for a 42" or 48" (when these where used here, they was always measured in inches, pretty international)
This hasn’t seen much use. I need to find some burlap to wrap around it, which was common during walking the woods.
I’ve tested this one some, but it needs some sharpening, altought it bites really well.
It has the “saw buddy” option, i need to find the spring and hook.
Bad pic, but it says made by Sandvik steel works, Sweden, model name Canada, as a “exotic” land representing big timber.
Edit: i forgot, it’s good to have some good cross-cut saws if all of my 178 chainsaws refuses to start, they are grumpy two-strokes after all…
About a week ago I picked up a load of firewood and for no reason at all I looked down a ravine on our land that is used as a snow dump by a company (with our concent of course).
Apparently other people like to use it too but not for snow… Saw what looked like a four wheel cart in decent shape except for the wooden drawbar between the axles, went there with my wife , hooked up some chains and we pulled it up with the tractor.
Feels like not so much work to fix it up.
The sharp eyed person can perhaps spot that it even has brakes on the rear axle, brake pads made of birch pressing against the inside and outside of like a piece of pipe. Disc brakes of sorts :grinning_face_with_smiling_eyes:
Don, did you notice? :smile:
