Thrive Off Grid
Hi matt The main questain i have for us poor folk wood chunkers, is what kind of wood crusher mill will turn wood chips non sorted intoo saw dust ready for pellot mill, most of the low end hammer mills had too sort wood chips too feed the mill too get clean sawdust. WHAT am i missing here. ? THANKS. P.S Your new shop yard looks nice and roomy.
Build that rock crusher its the same thing
Have you tryed the rock crusher yet on regular bulk wood chips yet.
If it can crush rocks it can crush chips.
Are you speaking of the hammer mill with the short chains welded too the shaft, i dont think the other vidio had no designs features showing.
Here if you want make a pellet mill. this is the cheap and easy way to do it.
Here is your how too video. If this hand grinder can do this, I refuse to believe that this is “high energy input” 600 watts to do what that grinder does in seconds!!!
If there was a local outlet too test green dump wood chips in, it would be worth building,? Ware too test a hammer mill , maybe farmers use different types of hammer mills, or same type.? different blade arangments for different feedstock types.??
post withdrawn by auther.
Here is a wood dust set up briquitte maker, must be 8 too 15 % dry sawdust or shavings, still needs too be dry. So no gain on dry time for 2-1/2 " od briquette.https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F323613106054 i think these big briquette pellots would be too big too make enough fuel power, being there are compressed larger peice’s.
Thats pretty pricy, even this is a bit expensive but this and a little chipper is all you need.
Im going to make mine; $350.00 bucks for the 5" die set is hard to beat. I can make the rest pretty easily.
You could make one and sell if make momey at it. Do the pellots need be dryish too work good while makeing.? I wounder if reback chunker size wood would work better in the hammer mill too make sawdust shaveings.
yeah I dont know. Im trying to keep it simple and just use my cheap ol Harbor Freight Chipper. If it dont work Ill make it work. I cant afford a rebak so the HF chipper will have to work for me.
A hammer mill is as simple as it looks dont over complicate it. Try building just like in the videos. If it dont work try different chains or something. Maybe chainsaw chain?
Another thing you can build is whats called a crumbler. It is sort of like those shredding machines you see. but this works with smaller blades like in a circular saw. In fact if I build one that is what I will be using. These would turn anything to small fine shreds with very low energy consumption as they are slow turning. Ive built these for another company Ive worked for in the past. Kinda like a paper shredder on steroids.
Crumbler, i have too be looking that up for a while, thanks on that search criteria name. probbly a non available tool on ebay.Comercial unit.
You wont find one, proprietary. This is as close to one as you will find.
That looks like a cool shedder, if the blades were easy too remove as posible, and able too sharpen and reinstall with thin washers if needed too maintain proper blade tight clearences.
Thats why Im going to use small circular saw blades. You can get a sharpener from Harbor freight.
That sounds like it might work better at high speed too make small enough wood particle too fall down in those pellot holes, if the chips dont fly around.
Maybe slow would be better. Probly only need about 6 inch shafts. Good luck with that refinement tool. I been wanting too buy one of them saw blade sharpeners for ever, those aluminum ones might not be too bad.I think the 160$ ones.
