Seriously?
This is a consideration
Well, it’s the main meal on the North Korean platter, but putting aside the current saber rattling, last week we missed a CME by about 6 days that would have quite likely wiped out the grid. Nothing conspiracy theory about a Carrington event.
As far as smaller electronics are concerned, unless an appliance is plugged in during a CME it shouldn’t be fried. The main danger from a CME is large infrastructure, transformers overloading and popping.
You can also just store a vehicle in a metal garage building and that will essentially act like a faraday cage, the metal body of the vehicle also will block it somewhat.
How many pounds of boost do you think it would take to compensate for the power loss between wood gas and petrol on say a standard 8.5 to 1 CR engine.
Romania
Money well spent because the burger shakes are bomb proof
Tom:
The figure out the boost you need you have check your gas consumption at full power
Then calculate you power output ( or Dyno ) the do the math on flow rate be and plug that into a formula to get a boost number
But if you had to guess how much boost doubles your hp on gasoline and go with that
I’d dig a big wide trench and bury that thing for a bunker or at least a root cellar. I’m not crazy. Maybe a little eccentric.
Some of those old coaches make a real nice inexpensive home on wheels
the engine and trany are not that hard to work on.
But they are getting rare.
I hate to see them get buried or left to rot.
Wow, Mine’s a TDM 4801, what’s yours? … I actually have 2, both are 1954. One is an intercity bus, (like yours) and the other is a Parlor Diesel.
MAX transit from Birmingham, ran route 6. Can’t find any images of it in service. Whats the serial number?
I will try and find some numbers tomorrow.
Should be a plaque right inside the front door on the lower dash panel. ill probably start with GM TDH …
Hello William .
My bus is
Type TDH4512
Coach #45122926
Serial# 2926 (2838-2937)
Birmingham Transit Co (AL)
701-800 (789)
Delivered into service 09-11/58
It’s a 1958,
Transit (Not a PD or Parlor Diesel) (More Head Room!)
6-71 Diesel Engine (Inline 6 cylinders - 71 c.i. per cylinder, 2 stroke diesel)
Hydraulic Transmission (Automatic!)
45 passenger
Model 12
Length = 35 foot / Width = 96 inch
Manufactured from 1953 to 1959**
With this info, you can go to the Birmingham AL bus company and get all the routes and the entire history of your bus. I have all mine including photos, even found some original hand bills that showed the route maps.
COOL BUS!
