WK for portable generator
What were you trying too catch the coon with / or how did you catch coons.
I don’t want to hijack Tim;s thread but in the above case I threw a light coat over it and everywhere I garbed the coat would be met with sharp teeth. I was through playing much quicker than he was through fighting .
Those coons can be a REAL pest if you slip.I wont be trying that catch any soon time,
Hi All
Gen fueling and duel flaring of extra woodgas sounds like a nice doable solution. Yep. Sounds nice.
In real use becomes a biting-back coon real quickly.
Gen-set with variable electric quick-in and out added and dumped-off shaft loads is hard enough to accommodate for a steady even mixed dragged/sucked trough air/fuel gas mix.
Now add in a pulled/sucked/pushed-to woodgas load to a flare nozzle!!
Often the variable gen load will woodgas flow starve the flare snuffing it out. PITA. Get to breath in raw CO constantly flare re-liting.
Often you will suck back the flare/flame up-gas stream resulting is a system Ka-BOOM evnet.
Been there. Done that.
One of those seems simple solutions that bites back hard. Leads into much thinking about quick action pulsations valving. (which adds costs, a NEW system PITA dynamic).
Becomes the swamp of alligators eating up your time and efforts when all you wanted to do was make a simple personal 2-par course out of a wet bottom…
Just saying.
By all means go ahead.
You all let me know how you make out. The IISC India people beat head on this too and gave up.
