Wood gas engine valve lubrication/cooling
I have a "37 Farmall tractor that has the regular gas tank and a separate one that holds about a liter. Start it on gasoline from the small tank and then switch to kerosene from the big tank when warmed up. It also has shutters on the radiator to help heat the engine up. As you said; the price of gasoline is cheaper than kerosene now so I don’t use the system. TomC
