Tone,
Are you using any diesel fuel in your tractor now?
Tone,
I’m really happy to see you rewarded for all your effort Goren. Another chapter in our joint efforts at self sufficiency. Our mutual understanding increases with every builders accomplishments. I cannot help but believe that your success is mine as well. It brings to mind a poem I have always taken to heart. Understand that what I am saying is that as each man’s death diminishes me so in the eternal balance each man’s success increases me. Thanks for taking the time and effort to share.
For Whom the Bell Tolls
by
John Donne
No man is an island,
Entire of itself.
Each is a piece of the continent,
A part of the main.
If a clod be washed away by the sea,
Europe is the less.
As well as if a promontory were.
As well as if a manor of thine own
Or of thine friend’s were.
Each man’s death diminishes me,
For I am involved in mankind.
Therefore, send not to know
For whom the bell tolls,
It tolls for thee.
Drove some on wood today, worked nice, some minor fixes to be done.
More videos will come, this one ended suddenly, because i must have accidentally touched a button.
Also worked some on the scraper drive:
Found a sturdy old windshield wiper motor, it hid in a bucket of rusty door hinges i saved..
Thanks Goran, I loved it. Why is your fuelratio meter jumping?
Goran, thanks for the Sunday evening ride (for me)—Very enjoyable. You do excellent work. Thanks for sharing.
Thanks for the ride Göran, what temperatures do you have coming out of the gengas unit?
Do you have a broadband lambda or a regular one, and where is the sensor located?
Congratulations Göran! Always a nice feeling when efforts pay off. Love your videos.
The words of our leader Mr. Wayne: “if you have wood, you will travel”,… there is nothing more to add to this.
It is nice to hear an engine that breathes on wood gas and devours the road, it seems to have good power and stable operation, …
I have become “spoiled” regarding the quality of the gas and the resistance of the entire system to the intake manifold, my parameters for this are:
I know that the rest of you have slightly different criteria, but we can compare them with each other.
Many compliments Goran and best regards!
Thanks for all the kind words guy’s, it’s really great to have it up and running again, i’ve could have put some more effort and get it ready earlier, but there is always stuff in the way.
To answer @Jan , i have a narrow band lambda, the cheapest Bosch copy i could find, it really only tells if im on lean or rich side (this also answers @Pelletpower s question)
It’s placed about 150mm after right side exhaust manifold.
My temp sensor directly after gasifier has stopped working now, i probably stretched the wire when lifting off the hopper.
My temperatures before rebuild, if i remember correctly, used to be around 150-200°c, sometimes 250. When reaching 300, there was often some trouble, low on reduction char.
Ok, thanks for the answer.
It’s strange with my cars that they run so hot.
The red one is about 350-400c at 80-90kmh, and after I sealed the small crack it runs really well, the coal has become more compact under the wood as well, it runs on gas after a few hundred meters, I wonder why mine runs so much hotter?
You put a big smile on my face Goran ![]()
JanA. you run with mostly conifer spruce, is this correct?
The wood species; and the part of the tree it is from in my experiences makes a big difference in the rates of conversion. Conifer trunk/stem woods are a “fast” wood. Fast conversions makes for less time for the heats to be internally utilized.
Sometimes, “It Is; what it is”. Be happy with your engine power.
Regards, Steve Unruh
I’ve actually been running on birch for a few weeks now, the same small pieces that JO uses, so it can’t be that, it must be something strange that I’m doing with my gengas units.
A little report on the truck: I’ve been driving it some, to work, to recycling plant, various unnecessary driving, it works very well, more stable operation, for @Jan , thermocouple reading gas out of gasifier came to life, now and then, dies again, seems i have a little higher temperatures than i remember, 250-300°c , pretty stable readings, nothing wrong.
I have a leak in ash-cleanout lid, and in hopper lid, not enough to do any harm, but it keep smouldering some time.
When i should drive home from work it had been standing for 9 hours, and greeted me with an enormous explo-sneeze, when i started the blower, cleaned out one of the condensate drains pretty good, it was needed anyway.
This wednesday i was invited to a local church, monthly lunch gathering, to show-and-tell, it was much apreciated.
Going to re-seal the lids tomorrow, well, i just remembered im out of red-rtv-sealant, so instead i try to mount the grate scraper motor. I have noticed higher vacuum readings than before, not much, but noticeable, which indicates the new grate works as intended. Im just going to drive like this, until it seems constipated, then im going to open up the air for the Tone-nozzle, and see how it reacts.
Some pic’s
I managed to pry the old seal out, cleaned it, and made a new stove rope/ silicone seal.
Goran,
The stove rope I get locally appears to have graphite imbedded in it. Will that work okay with RTV silicone sealant to make lid gasket?
Hi Steve, i’ve tried it once, it was pretty clear that the silicone wouldnt stick to it as good as on ordinary rope.
I did the trick i’ve learned here: to put the rope in a plastic bag, put in silicone, and “knead”, the graphite treated rope was kinda “repellent”. For a critical seal, i would’nt use it.
Thanks for the posts, Goran. Lately, I’ve strayed quite a bit from the “wood gas” program into the realm of “electricity.” It is fascinating, though, how well old engine technology (60–70 years old) pairs with modern technology—generators, inverters, batteries, and so on. Anyway, I need to get back to the gasifier.
How satisfied are you with the performance of the refurbished gasifier? Have you opened the air intake to the lower nozzle yet to test the effect—to see if it works better or worse?
Hi Tone, well it is all about energy right? Gasifiers, generators and engines.
I follow your posts with big interest, both gasifiers and electric stuff.
And as you say: old engine technology, stuff that was made to run forever, and easy to repair, works well. not just as the stuff off today, that is made to be thrown away when it breaks…
About the Chevrolet, i haven’t been driving it enough to try it out, only some 150km, but it runs real nice, stable operation, stable idle, good power. Only thing bad is the long start-up time, but that is just a matter of the leaks i fix at the moment. It burns out a hollow in the char zone when parked, very clear when feeling the charbed with the poking rod.
Thanks Goran,
That’s what I thought. I’ll order some non-graphite type before I do a lid gasket. I have been using a rubber barrel lid gasket so far. Have had to replace two or three of them. I think they don’t handle the heat very well.
