# Blowers
**URL:** http://forum.driveonwood.com/t/blowers/957
**Category:** General Discussion
**Created:** [October 4, 2013, 4:54pm UTC](http://forum.driveonwood.com/t/blowers/957 "2013-10-04T16:54:25Z")
**Showing post:** 33
### Author: ![SteveUnruh](http://forum.driveonwood.com/user_avatar/forum.driveonwood.com/steveunruh/32/45324_2.png) [@SteveUnruh](http://forum.driveonwood.com/u/SteveUnruh)
#### Post date: [October 6, 2020, 10:24pm UTC](http://forum.driveonwood.com/t/blowers/957/33 "2020-10-06T22:24:59Z")
Yes. I have used many of these. 12VDC as noted. Very watts use efficient. Brushless. Sparkless.
Been used pictures here :
> [@Ben Peterson's new Gasifier Plans?](http://forum.driveonwood.com/t/ben-petersons-new-gasifier-plans/1306/10):
> Morning All This BensGift book built plans gasifier system is a DO-IT-YOURSELF plans-set intended to be ran on WOOD fuel unit. DYI intneded is why the “wet” hay-straw filter versus a “hot” exotic material filter. Says these things right in the title. WOOD. BUILDERS. Just like GEK really does mean Gasifier (all bio-fuels) EXPERIMENTERS Kit. Both of these really do have honesty in presentations. Now IF YOU try and read more into their presentations that is on you impressing/misrepresenting yo…
The 12VDC made-in-USA AMETEK’s were a bit more higher flow at ~2X the watts needed. As I recall a bit over 150 watts. But 2x-3x the price new for the 12vdc versions.
Larger systems: or to double up blow and suck you would use two of these.
As MattR says to get the really high flow capability then use a 115/230 volt AC version power supplied thru an inverter from a battery bank. And big enough inverter have some extra AC too.
_[View the full topic](http://forum.driveonwood.com/t/blowers/957)._
