Sean, is it 4wd? What range do you anticipate with a full hopper?
Only two TC’s ? They look good built in over there. I like that.
Hey Carl,
Thank you,
That idea had me puzzled for about an afternoon. Required a small amount of custom work with a rotary cut off tool. I like it good spot easy to read. Managed to keep the cup holders on this one. Haha
Bill
This is a fully function 4x4 model. Hopper is good for 50 miles depending on variables. Just breaking in the new gasser.
Looks and sounds great Sean !!
Hi Wayne,
We all know how long it took. In the end way worth it sure is a sweet truck. Just tap the throttle and your doing 90mph so I am easy with it.
“SOUNDS GOOD” P.S. I think someone retro fitted this truck with a Dodge VIPER exhaust, Thank You to the donor car.
Hey Yeah! Sounds and tire smokes great SeanF.
This the system for someone with a real Need for Speed.
Your “SeanBuilt” system look to be all above bed?
Is this slide in/out removable for those problems pesterer’s in Life?
You are one of the true woodgas Practicalists. Not geek bone in your body. Instrumentation is for Operators.
Best regards
So Sean, is it worth stroking to 390 on wood? Did you do any other modifications like higher compression pistons?
