WARNING!
I have another mechanic question.
This one is for those of you who like puzzles.
EDIT: I think I figured this out, but Iāll leave this up for those who might be interested. the answer is at the vvery bottom.
Does anyone out there have some good general knowledge about 2013 era chevy (malibu) 4- cylengines ā¦
GM canāt seem to help me. I got myself into one of those āhelp-a-friend-of-a-friendā dealsā¦AARRRGGG!
The short of it is this:
Exhaust camshaft-driven Vacuum pump came apart and broke the position sensor counter off the camshaft. caused an oil leak and a CPS code. I intended to replace a seal and sensor as a favor kind of thing.
Bu, Since no good deed goes unpunished, when I pulled the pump to fix the sealā¦
I ordered a camshaft by the VIN. It was not slotted, but I used the orientation of the counter to weld my counter on and it did not work.
I then used a picture of a 2.5l cam to orient it and tried again, it is obviously not firing at the right time. Like in the old days when you would install a distributor 90 out or something.
Now the real problem.
GM will not even touch the engineā¦replacement only. so guess who gets to tear it apartā¦Yay!
Now for the really real problem.
VIN and hood sticker call for a 2.0l engine.
But the GM diagrams, online diagrams, and actual parts bought for 2.0l do not fit. Camshaft for 2.0l is not slotted for the vacuum pump.
According to GM there were 4 engines available (4cyls):
- 2.0l which has turbo and seems to have no vacuum pump (but not sure)
- 2.4l with direct injection, non-turbo, totally different vac pump and head and valve cover, etcā¦= very different in appearance
- 2.4l non-direct injection, similar in appearance but not turbo and not slotted camshaft
- 2.5l slotted camshaft like I have, vacuum pump like I have, but pics of application in used cars differ with air ducting, hoses, etc⦠And the orientation of the counter does not seem to work correct.
One other piece of info. The car drove to the shop. It died a few times as it set cam position codes, but it was running, so it is unlikely that there is other significant mechanical failure, i.e. broken cam shaft, jumped time, etc.
also, Coils and plugs are firing, and noid pulse is injecting fuelā¦so I didnāt fry anything when welding the counter on. It just seems to be doing those functions at the wrong time.
So, does anyone out there have any experience here. My thought is that someone pulled a 2.0l out and slid a 2.5l in its place, leaving the turboā¦but It seems like it would be a lot of work to do so.
At this point I am open to most anything. The customer would like to put a used engine in it and move on, but I canāt really identify the engine well enough at this point to replace it. I suppose that is the real question I am asking; what engine am I dealing with here. ANy ideas on how to figure it out. ?
Edit: I just received a diagram from GM that pretty clearly eliminates the 2.4l, as the head and VC is totally different, no vac pump, etcā¦
EDIT: ANswerā¦2 parts
Two different GM parts departments sent me the wrong diagram for the 2.0l head assy. Turns out their computer system is wrong. They have the pictures for the 2.5l in the directory for the 2.0l so that when you look at the diagram for the 2.0l you are actually seeing what looks like a 2.5l. It is also the same diagram system that all the online parts aftermarket companies are using for identification.
This is apparently a system flaw globally for GM. At least thatās what one of the parts managers told me.
2nd part of the answer. The camshaft I ordered for a 2.0l from an aftermarket dealer because GM has discontinued it,ā¦was actually the wrong part. They sent me a cam for a 2.4l direct injection engine.
SO, both of my ābelieved-to-beā acurrate measuring sticks were wrong. I think we figured it out. It is simply a 2.0l engine as the VIN and hood sticker call for.
It is funny too, yesterday my son said, āDad, are you sure itās a zebra and not a hidden horseā. I was sure it was a zebraā¦LOL. But, no, itās just a horse and a couple folks who are a certain part of a horse.
