Air Carbon Fuel Cell
Since the gas is removed as fast as possible without traveling through the charcoal fuel supply a gas cooler is used. It is a pipe inside of a pipe with tangent inlet and outlet on the outside pipe.
Hmm, I forgot to take a photo of the complete cooler. I’ll do that later.
This is the inside pipe. I like to oil it with canola oil at least at the bottom so that it slips into the seal made from tractor inter tube.
Top of inside tube. I hammered the end over on an anvil (lip) so that the top seal, cut from an inter tube, does not slip off.
Pipe being installed, almost installed.
bottom with inside pipe installed.
The bottom seal.
The top outside pipe seal mating surface.
the top with inside pipe installed.
Hi Jeff
I think Koen says that the gas produced in negative pressure is better than the gas produced in positive
pressure!:thinking
Thierry:
Just a couple photos of a lonely producer sitting in the shop, wondering what it will be doing in the spring.
Jeff,
Is that a cyclone with filter above? I like it!
Bruce, you nailed it right between the eyes. It is a thermal-cyclonic-transformation-fuel-separator.
Jeff, does the cooler tube also work as a spin filter and collect char dust in the bottom with the water condensation?
Hi Bob, Water will collect on the bottom, sometimes, Dust and condensed water collects on the walls but not as much as one would think. Well, one time when I over sucked with the starter fan I found an amount on the bottom with water.
what level of efficiency do you opt for with this equipment?
It is different than I thought. I see that it is more of a cooler than a cyclone. I didn’t realize that the center tube was a passage for cooling air. I thought you had a cyclone with a sock filter chamber attached to the cyclone outlet pipe.
Please stop posting those nice builds… my like button is getting worn out…
I love the thinking behind your build…
I was just having fun with words, it is just another gas producer.
Efficiency, now there is a can of worms! For this old boy, efficiency is really the state of being practical. How easy is it to use, how repeatably is it and how much maintenance is required. Anybody can cook the books to come up with a percent of efficiency but it is not easy to fudge those three things above.
Oh, you meant the cooler. I forgot to mention that I coat the inside with used engine sump Canola oil to stop rusting. That is why some of the dust sticks to the walls and doesn’t fall down, Next time a stainless inside tube would be my choice. I’m thinking; if the inside tube rusts, it might wear the rubber seal when installing or removing. But I bet it would be microscopic, in other words not a real problem.
Hi Jeff.
You asked me to make you a clean sketch of your producer so I have studying this topic from the begining, and follow the different modification that has suffered your desing…when finally in post # 85 I saw your skecth.
Please I will need some basic info:
The type and size of the engine that this producer feeds, and what kind of vessels are you using for the top hopper and for the reactor, Some sizes??
BTW: I think that the reason why the reactor work better without the spacing wires is because the inlet air has to squeeze between the pan lip and the bottom of the reactor this way he air is being better preheat (hotter) because 100% of the air is “licking” the bottom of the reactor that is hot.
Jeff
it is not possible for everyone to imagine new configurations :wink:
Thierry
Yep.Yep. Well, well said.
Efficiency mania of each separate step DOES not lead to “better” usable results.
Just spends a lot of non-replaceable time and money’s.
Every single failed 1990’s idealized “better” bio-mass systems failures can be traced back to sinking from obstinately insisting on single failure point better-efficiency blockages. Gas turbines & Stirling cycles engines versus proven IC piston engines. All-biomass systems capability hinted at by slit-hearths with formed “fuel-cubes” and/or plasma & fludized bed systems with ground particlized fuels versus just chunked woods and made and sized wood-charcoals.
Read these Idealization efficiency chasing’s and weep.
tree-farmer Steve unruh
Engine = 212 cc (6.5hp)
Top tank = 20 lbs propane tank, ~12" dia (~30cm), ~ 12" tall (~30cm)
Bottom tank = 30 lbs propane tank 12" dia (~30cm), ~ 18" tall (~46cm)
Center tube = 5" dia (~13 cm), ~ 3.5" (~9cm) between tanks, later I’ll see if I can find a photo to guess how far it protrudes into the bottom tank.
Cooler = 5" (~13 cm) dia outside pipe, inside pipe 3" (~7.6 cm) dia., forgot to measure length.
Air squeeze could produce some swirls that mix with the steam? I don’t know.
Hi Jeff:
Please find attached the sketch you asked me to do for you of your producer/cooler.
Best Regards.
Eddy Ramos (Argentina)
Eddy, your are amazing!
A couple comments:
The bolts, that help grip the refractory, are covered with the refractory. The bolts are not exposed to the charcoal or glowing charcoal.
No bottom/side clean out on the cooler. The inside tube is easy to remove, serves two purposes and no tools needed to remove.
Many thanks,
Jeff
Where does the air come in? nozzle? what am I missing?
Al
When i first saw this at Argos I had a difficult time understanding what was going on. Jeff kept telling me and I still didn’t get it. This is what I left with and jeff can correct me (again) if I misunderstood.
When running the pan underneath is held off the bottom of the producer a little ways allowing the air in at the bottom. Shut down the pan is sucked up to the bottom of the producer shutting off the air flow.(springs) It is so simple that this mind couldn’t see the forest for the trees. My mind was struck in downdraft mode that I couldn’t recognise updraft mode let alone only halfway up updraft. More hopper on top.
Ok Jeff you can now chastise me.
