Yes, thats perfect! Never seen such material. The pads here cant be unrolled like this.
Yes, it is made as one long continuous tube. I pulled it over the pipe then twisted it a bit o give it some thickness.
Great idea Bruce now the holes can’t be blocked, the more suface area is better for sure.
I like the whole KISS design here. Got to make one for my genset.
Brian, I forgot that my cooler piping actually goes down into the filter can. So I may need the drain you recommended. Thanks for the tip.
Sunshine and warmer today so worked on the tractor.
Battery and filter installed.
Safety filter and crankcase screen.
Not sure yet where to install the O2 sensor for AFR gauge?
Hi Bruce , i just looked up that Lakos ,Twist to Clean filter that your using on your build , for something else i am playing with very interesting , but costly so will keep and eye out for thrown out units .
Keep up the great work, slow and steady wins the race for sure in winter time .
I tried to run the engine with the oiler. Works great as a drip control in open air but was impossible to adjust when screwed into the intake. The engine vacuum turns the drip into a stream. I played with it for about an hour. I had to kill the spark on a few engine runaways. The flood of gasoline was squeezed past the rings and into the crankcase. Now I know why Henry Ford took the glass out of his oiler/carburetor.
So, I’m going to raise the oil drip with a nipple and coupling. I will tap and plug the inside of the nipple where it goes into the intake. I will drill a tiny hole through the center of the plug. This tiny hole will be just large enough to suck in the drips of gasoline and still maintain the engine vacuum. The coupling will have a large vent hole drilled in the side to break the vacuum on the oiler. Voila, a drip carburetor. Wish me luck!
OK, my drip carb works now. My drip jar was a little too close to the hood so I used two 45s to offset it. I tapped the inside of the upper 45 and screwed in a plug. The plug has a 1/32 hole drilled through it. And there is a 1/8" hole drilled through each of the four sides just above the plug.
I was hoping to have more progress to report but I’ve been stuck working on the voltage regulator. I didn’t know that there are type A and type B starter/generators and corresponding regulators. Type A moderates the negative to Field connection and type B moderates positive to the Field. I’ve decided to add an amp meter to the charging circuit. I’ll need a good generator and battery for starting and for a front-mounted winch.
It is warming up some but there is still snow on the ground. Slow progress on the Baron. There are 5 new pieces in the picture below. Amp gauge, AFR (O2 sensor) gauge, reactor temperature display, water drip PWM control (black knob above display) and shutoff valve for the vacuum gauge. When running with the drip carburetor the engine vacuum is too strong and pegs my “inches of water” gauge.
Wow, this is embarrassing but life happens. It has been a year since my last post on this project. A few additions and changes. Added a winch to the front frame. This puts some weight over the front wheels and gives some electric muscle for pulling logs out out of the undergrowth. Replaced and moved the voltage regulator. The original regulator was crammed into a tight space under the steering wheel and dash. New regulator is now in a convenient spot. Added a tachometer to the dash. Replaced the old ignition switch. Hooked up the cooler to the reactor. I hope to find time in the next couple of weeks to fire up the reactor, but don’t hold your breath.
Preaching to the choir, Bruce. I built a new gasifier for my saw mill last summer and then it was harvest time for the garden and then a couple of months of fire wood gathering. Winter came with feet of snow. Still waiting on spring but I’m going to fire that sucker up, I swear. I used to be able to work more than 4 hours at a stretch, so that;s one excuse, but I’m amazed at how much stuff Goren and Tone get done every week.
Bruce,
What are gas coolers like you used called? Would such be available on ebay?
Hi Steve, It is used steam heat pipe from an old warehouse. Zoro.com has it for $240 for 4 feet.
The “cooler” is called Beacon Morris Steam/Hydronic Heater Element.
Bruce,
Thanks. I’ll check it out.
Getting closer. Today I did a smoke test with my new Temu toy. Amazing! It filled the whole reactor, filter and plumbing. Found 3 tiny (invisible with out the smoke test) leaks: 1 at the tuyere weld, one at the reactor outlet and one at the end of the cooler. Next up water injector test.
Tested water drip today. Mister nozzle with shutoff.
Low power pressure pump and tank with filter. I added instant coffee to water for better view of sight glass.
Pulse width modulator on dash. Adjustable from one drip per second and upward.
I like your “B for Bruce” tap handle fixed to the valve there.
I’m concerned about the Leidenfrost effect (hot skillet) causing the water to ball up and skitter out of the tuyere pipe (occurs at >379*F). I think I will lay a piece of exhaust pipe wrap lengthwise in the pipe to prevent that.
Definitely worth a shot, when I did my simple drip for the flute updraft I just put in an elbow on one end and I want to say I drilled a pipe plug to fit my stainless drip tube, so it at least kept any droplets skating around to eventually boil off. Also made it easier to shut down the Mazda with pipe plugs.
I would like to make up a Pederick Plate style tuyere and have the air entrance and exit holes be in the upper 1/3rd, or have the exit hole close to the bottom and have a welded tube that snorkels up to the ceiling of the box. I think the pipe snorkel would make it annoying to clear out slag, though, considering it would be welded up inside of the box.
