Building kinda of an gasifier, raw bamboo is the aim
lets try a prototype … Reviving an old project…
Building a firetubish thing first…
Thanks for the two pictures with you in them K.VL
After your different hospital bed pics good to see you up and working it.
But especially it gives scale to your current project. BIG. And going to be heavy in that thick SS. Stationary?
One way that bamboo is different from wood is the composition of the ash. Bamboo ash is high in potassium and silicon. The potassium is certainly a resource to be recycled if possible. The silicon may end up being especially abrasive in an engine if not filtered out of the gas stream.
Wood ash, like the kind from trees, is high in potassium and/or Calcium. Silicon is negligible from the wood itself though bark and dirt carried over from processing can contribute to a material amount of silicon being present for traditional wood as well.
Bamboo is amazing. It is technically a grass and uses a four carbon fixing photosynthesis pathway that has a lot of advantages, among them drought and heat resistance. Corn(maize) and sugar cane are also C4 fixing and known for their rapid growth as well. Good luck making the best of a great resource.
Anthony, Koen has been working with bamboo for quite some time now. Mostly bamboo charcoal.
Hi Steve, yeah, still up and running… but to little time on DOW…
Yes, this one to run stationary, testing different things… one is for boiler fuel gas purposes, ( running dual fuel in burners with plastic heavy oil )
second is running generators, probably also trying a Brandt gasifier… mixing both worlds Raw and charcoal.
New in the make: a temp controlled reduction zone, both electric and extra oxygen.
I have been experimenting a lot… hahaha…
That is one heavy duty wood prossing burner for making charcoal gases. And charcoal?
Hi Robert, :grin: yes, trying to melt some metal …
Hi Robert, kind of missed your question, this one intended for raw bamboo, downdraft, some mixture of all things i presume should be the right way … intend to over drag and compensate temperature with condensate, water, oil or other substances…
Sorry I should of said raw bamboo instead of wood habbits of the not so far West. I like how it looks, it is going to work for sure. What are you going to call this unit?
Taking a stainless flange as choke
Enlarging the opening to 135 mm
Welding in place
Proportions here make me think of a WK. Is this designed for variable load?
Hi Rindert, this firetube is pipe from scrapyard, 12" diameter.
Not sure if it would resemble anything else as a imbert style so far
It is meant to be a test for stationary load with bamboo fuel. and follow up on gas quantity/quality for either boiler burner or possible generator.
Will try to run generators in dual fuel diesel/woodgas as i also make diesel fuel from plastic waste
Cool! Could you point me to info about how to do that?
Biomass gasifier, plus oil or plastic diesel
Hello Koen,
two small details, finally to have no preferential gas passages, I usually have the air injectors in an odd number, so the injectors are not opposite, therefore more homogeneous, and also, now I orient at 35% upwards the air injectors, this causes them to race upwards first before descending, therefore a wider working coverage, and I sometimes also push at an oblique inclination, causing a vortex, this makes it possible to pass very large volumes of biomass by treating it in an optimal way.
Heavy duty = hard labor…
The testing hopper consist of 2 cooking pots in stainless, volume total 80 Liters.
Next level would be drums 55 gallon stacked on top each other… Who knows…
The ash receiver is same diameter as the 55 gallon tanks
Fun with hard work…
Sizing…
The transition between fire tube and ash receiver is a clamped version, rope seal between
difficult to stop…
I like the clamp idea you have there Koen.
