I HAVE A 1& 1/2 TON REAR AXEL STICK ,350 GEAR RATIO,HAS THIS SIZE BEEN USED AS CHUNKER AND OR HOW WELL WOULD IT LIKELY HOLD UP.
Hello Kevin .
I guess the above would depend on how big of chunks you wanted to chunk.
My chunker has about a 2 inch diameter axle and the pinion to ring gear ratio is about a 6 to 1 .
