Coke from the railway tracks
Here is a question:
I walk a long a set of tracks often enough to spot the coal and coke on the ground and wonder how this fuel would react in a gasifire.
The coal I can see being very dirty and prone to clinkers.
Anthracite coal (hard coal) can be used in a charcoal gasifier if used in limited amounts. Coke is also OK in limited amounts too, but you could probably use more of it. Bituminous coal is a NO GO. Too much silica and it will gum up your nozzle big time.
Gary in PA
Every walk I pick up a bit more these days.
The coke is worthy of more attention.
I have not been able to burn any pieces of it.
I assume its because I need to keep it hot to burn.
My wife has taken note of this collection and said she is apposed to more " junk" brought home.
So my coal and coke experiments will have to be small.
I’ve burned about 4 tons of PA anthracite coal in my bucket-a-day, hot water heater, and I found it to be rather nasty when it comes to rotting metal out and the fine ash dust sucks.
I have some experience with coal.
I ended up with tons of it (literally). It was free, so I thought “what the heck.”
I have not yet had the nerve to try it in the gasifier.
I an not even sure what kind I have.
Some of it looks like anthracite. Other bits look bituminous.
It is just stacked outside in big piles.
When I light it (which is challenging), it produces a lot of nasty smoke (gray then yellow) and smells bad for a while.
Then it starts burning pretty clean, and very hot.
I have used it to melt aluminum, etc.
But every time I use it, it seems like it is hotter / more corrosive than charcoal by quite a bit, and very hard on steel.
I have given some consideration to “coking” some of it in my charcoal retort, and trying it in the charcoal gasifier.
But I thought I would save that for a later experiment, after I have all the kinks worked out of the charcoal system first.
I never worked on the coke batteries, but I work down wind of them and let me tell you there is a lot of nasty things in there lol.
But once coked I know its a fairly clean fuel.
I wonder if I have real coke here or a blast furnace by products?
Its not slag too light and its not coal.
Great video:
And Mr Leeder is willing to chat about this video he made in the 60’s
