3D model of a cone
DownloadFree 21 day trial
Buy NowOnly $39 USD
Cone Layout is a program to unfold a frustum of a cone and generate a sheet cutting layout or flat pattern projection that can be rolled or bend up into a truncated cone shape. Either side of the truncated cone can be tilted. To help you visualise the cone you are editing, a rotating 3D model shows the dimensions.
Terry L introduced me to this program a couple of years ago… sadly I lost it awhile ago, and switched to linux… it will run in wine on a linux based machine
If you ever needed to make a cone this is the program for you… the trial works very well.
