David's Stationary Gasifier
https://forum.driveonwood.com/t/wood-fired-gas-generator-Kolyvan-9-0-version
DavidP. it was not you.
I fixed the topic links and they work now.
Joni’s systems are one to look over carefully as they are extremely simple and on 53 YouTubes, he showed they were very functional for his GM variant car.
On the version 8.0 he show internal dimensions. Careful. The numbers are correct but his loaded up diagram is top to bottom compressed. And side to side stretched.
The version 9.0 he shows his progressive improvements. And he pictures it cut apart after hard usage to show real in-use changes.
He was before the Russians invaded working on a version 10.0 now that he had established his configurations. It was to be in stainless steel for burn-through and internal corrosion resistances. And that one possibly licneced for manufacturing.
He did not design specifically for DYI’s guys to be able to copy. He is a superior welder on used, thin steel sheet metals.
He did design from version 7.0 for one man liftable weights. He did finally achieve this with many changes. His hopper lid rod spring steel latches are the simplest, lightest I’ve ever seen.
And on a driver present vehicle application as Kristijan has pointed out; Joni did not specifically design for unattended operation.
Still Joni was not afraid to woodgas his GM single overhead camshaft engine.
