Deals On Wheels 2
http://nh.craigslist.org/pts/5407795906.html
V10 Drive Train From 1998 Dodge Ram 2500 4x4 - $1000 (Canaan, NH)
V10 Drive Train From 1998 Dodge Ram 2500 4x4. 488 CI 8.0L. 4 speed automatic (47RE). Transfercase is an NP241DHD (heavy duty version with the PTO port and large output housing).
The truck runs and drives great. There are 87,000 miles on the truck and it has never plowed. I am robbing the body parts to put on another truck of mine and I don’t need the V10 power. This could be a great drive train swap for someone with a 318 or 360 (5.2L or 5.9L) or someone needing to replace their V10 or transmission.
The engine will come complete with the wiring, computer, radiator, hoses, fuel tank, exhaust, motor mounts, belt, accessories, fan, etc.
If someone is interested in it they can go for a ride in it before I pull it apart. It will only take me a day to pull the drive train once I have a deposit in hand.
http://www.usednanaimo.com/classified-ad/dodge-ram-heavy-duty_26679652
$3,500 · dodge ram heavy duty
Dodge 4x4 v10,new track bar o2 sensors brakes and brand new bf all terrains ko2 tires, some rust but runs and drives great. Bought new truck gotta sell. Perfect for work or towing.
Dakota, https://oregoncoast.craigslist.org/bar/5360478285.html
They don’t use salt on the coast so, it should be pretty good. I missed a '94 4 wd for $ 1500 and had to buy another one for $ 6200. I have a place in Myrtle Point and a couple of friends in the area.
1996 dodge 2500 8.0 v10 4x4 mechanically sound
So, I have come across a really cool opportunity, and my 96 dodge 2500 has to go.
I love the truck and it’s very very solid, but this isn’t something I can pass up.
So here’s all info on the truck.
1996 dodge 2500 4x4 8.0L v10 gas, auto trans
-298km on engine and chassis < burns zero oil
-zero drivetrain leaks, all diffs, axle seals, output&pinion seals, tcase & trans all bone dry.
-has a minor valve cover gasket leak, new gaskets sitting in the back seat. ( with any real interest/the right price I will professionally install them for you ) leak is minor, does NOT leak enough to drip or smell.
-full front end rebuild three days ago ( Jan 20/16 ) including all 4 ball joints, both axle ujoints , both calipers, fresh raybestos EHT pads, drilled and slotted rotors, & new rf wheel bearing hub assembly. ( 1000$ in parts and roughly 700 in labour ) all moog parts (lifetime warranty)
-has nice aftermarket shocks with no leaks & a small lift, I believe 4"? Not too sure honestly
-has rear airbags shocks & conventional shocks with no leaks
-tow package with trailer brakes wired ect.
-new water pump In summer of 2015
-new thermostat in summer of 2015
-very crisp ( relatively loud but not obnoxious ) dual exhaust manifolds back, with one chrome tip ( other one broke off hehe )
-truck is pictured on 35" dynapros but will not come with these wheels or tires unless I get asking price, it will be on stock chrome wheels with all season tires at about 40% tread
-transmission shifts very smooth no clunks even under heavy load towing. clean fluid, recently serviced.
-regular oil changes
-rear drum brakes at 60%
-park brake works flawless
-drives straight front end is tight needs literally nothing
-recently adjusted steering box and re- preloaded worm gear bearings ( steering wheel has no slop and very tight )
-body is in very good shape, no faded or chipping paint, very minor rust on front fenders and a very small spot on the box (both clearly pictured) underbody has next to no rust, and I’ve had it apart and maintained nearly everything on this dodge.
-interior is 8/10, has a cracked windshield and cracked drivers door pocket trim handle thing.
-small wear rip on the leather steering wheel
-truck will be fully professionally detailed tomorrow morning ( Jan 24th )
-no rips in seats and seats are very comfortable & not worn
-truck has been smoked in, in the past, not by myself but there are 1 or 2 cigarette burns in the back seats
I’m a mechanic by profession and I use this truck as a tow rig for my race car, successfully made multiple trips to penticton towing about 6000lbs no problem at all, with astonishing fuel mileage, I never calculated it , but it is much better than the v8 models and I was very happy with it. Made just under 500km to a tank hauling 6000+lbs.
I need this truck gone asap ( like tomorrow ) and I fully trust any owner would be happy with it. And wouldn’t need to fix much if anything anytime soon. I’ve been over this truck countless times making sure it is solid enough to tow my car without issues. I only took it off road maybe 3 times in 2 years… 4x4 works flawless, & is very capable in the bush for a full size dodge. It’s no Toyota pickup but itll get you through some mud/rocks if that’s your fancy.
I’m serious about selling this thing and it’s a good truck. Give me a solid offer ASAP and it won’t be refused. If not she’s getting traded in.
Definitely available for test drives & I can even throw it up on the hoist if you’d like, I can show you all the work done & the one thing it needs to be flawless (valve cover gaskets)
Thanks for your time reading my huge Ad
Please call or text Chris at 2506821596, or at work landline at 372-9900 ( The Garage )
99 dodge ram 2500 v10 8L
Hello I’m looking to sell my tuck. Only reason I’m selling is because it costs a bit to much for gas on a part time wage. Runs and drives great. 4x4 works amazingly. Has towed trailers in the past with no issue (it was previously a landscaping work truck that hauled trailers) . More details below.
About the truck:
It is a 1999 dodge ram 2500
laramie slt
It has a v10 8L
Extended cab
Long box
Automatic transmission
4x4 works amazingly
it’s got around 270,000 km.
The previous owner before me did a $10,000 motor rebuild around 60,000km ago have paper from original owner.
It’s had regular maintenance (breaks, oil, oil filter etc.)
Latest oil change done on January 8th 2016 oil and oil filter changed.
I have a toolbox for the truck I can throw in for an additional $200.
Cons:
Front left tire popped and currently has a full size spare on it. (Still have the original rim for it)
One of the pipes going into the muffler snapped picture of it is included (easy fix, small weld). Doesn’t affect performance just makes the truck a bit louder.
Couple speakers don’t work previous owner said it was an easy fix I just didn’t have the money to get it looked at.
Right side tail light is broken and has a wiring or fuse issue.
I’m looking for:
$2500 obo
http://detroit.craigslist.org/okl/cto/5416860820.html
2001 Dodge Ram V10 - $3000
2001 Dodge Ram V10 2500 4x4. New parts within the past year, new tie rod ends, Trac bar, u-joints, ball joints, water pump, tensioner and belt, alternator, radiator hoses, tips sensor, o2 sensors, transmission fluid and filter, shift solenoids. Replaced doors and fenders due to rust. Frame, floor and cab are solid. Runs, shifts great, 4x4 works great. Dashboard is cracked. Would trade for a pickup truck with 8ft box.
http://phoenix.craigslist.org/cph/cto/5416224781.html
V10 Dodge Ram 2500 - $3000 (Phoenix)
Hello. I have a 1999 Dodge Ram 2500 V10 for sale. Approx 177k on the mileage. Power windows and door locks. Sun roof, CD player, tow package, bed liner. Just replaced the battery and had a mechanic check the truck out. Mechanically sound! Interior is in good shape overall. Exterior is in good shape. Runs and drives well. I have no use for it at this point (I have nothing to tow!) Open to trades (or truck + cash) Good truck and would make an excellent work truck or hauling machine. Passed emissions and is good until May. Email me if interested $3000. Open to trades (F-150, Silverado, Jeep)
https://lasvegas.craigslist.org/cto/5416747415.html
Long bed v10 dodge ram 3000 - $3000 (henderson)
I have a 95 Dodge Ram 2500 v10 Magnum engine clean interior fifth wheel tailgate ac/heater Work has a low idle when AC is on other than that great running vehicle asking 3 grand is my daily driver it is a definite power horse has some body damage to bumper
http://up.craigslist.org/cto/5416752435.html
Trade lifted 2000 v10 Dodge Ram - $8000 (Munising michigan)
2000 Dodge Ram 2500
V10 488 (not like the ford v10)
103k
7" lift
New 37" tires
New 4:88 diffs
New wheel berring on drivers side front
One piece box
Crowl hood
52" light bar
Led interior lights
Strobs
Touch screen stereo
CB radio
Some custom body stuff
No rust
Amp and subs
Super chip
K&N intake
8k obo or trade
I have sleds and boats to add if the trade is worth more than my truck.
Give me an offer! The worst I can say is no
Trucks NADA is $7980 stock so I think 8k is a fair price!
If your not interested don’t message me with bs!
http://washingtondc.craigslist.org/nva/cto/5419082493.html
2001 Dodge Ram 2500 V10 185k miles - $3000 (Reston)
Truck is in good condition(and runs) but needs work. Recently power steering and 4wd malfunctioned because of the snowstorm Jonas. The truck is currently is in 4wd low. I bought this truck because it’s easy to work on. Changed all the fluids (powesteering, break, differential, and transmission). Replaced master cylinder and a break hose. Done other cosmetic work on it. Please email or text if interested. Clean title.
do NOT co
http://augusta.craigslist.org/cto/5424603405.html
98 dodge 2500 v10 - $10000
i have a 98 dodge v10 that i just did a complete rebuild on the engine. i just finished it about 2 weeks ago and its only been drove for about 50 miles since. im posting to see what i can get. either cash or trade wise. call or text me @
https://phoenix.craigslist.org/evl/cto/5425132016.html
1999 Dodge Ram 2500 v10 sale or trade - $8000
I have a nice 1999 Dodge Ram 2500 well taken care of but has some age. It is a v10 with 178xxx. Good tires helper springs in the rear. Has magna flow muffler. It’s not loud but sounds good. Only had three owner always kept in the family. I am willing to hear trades. Maybe a lifted truck. Diesel or car doesn’t matter I’ll listen. Text me if you have any thing or 8000. Obo not in a rush so I won’t get rid of it for nothing.
1999 dodge 2500 v10 with 97000kms
1999 dodge 2500 in excellant condition with 96000 kms. Comes with an artic plow . Plow just serviced at artic dealer and truck is inspected and ready to go with lots of new parts.
http://newyork.craigslist.org/fct/cto/5423951936.html
1996 DODGE RAM 2500 V10 ,8.0 L GAS ,4X4,AUTO,EXTENDED CAB,LONG BED - $4500
I am selling my black 1996 DODGE RAM 2500, 4X4,AUTO,EXTENDED CAB,LONG BED, powered by the torque monster 488 CI , 8.0 liter V10 gas engine which produce 305 H.P and almost 500 pounds of torque. New spark plug wires, spark plugs, air filter, fresh oil and filter, SOLID TRUCK, Good frame & chassis ,body has some dings , scratches and rust in the bottom of the driver side door only. I have a lower door panel that go over the rusted section, but haven’t got the time to installed, so the part goes with the truck . ROUGH PAINT job. NO ROT . HUGE MUD tires ,dual exhaust with 2 cherry bomb hi performance mufflers welded to 2 chromed side exhaust tips . HEAVY DUTY WORK HORSE . 160000 miles . EXCELLENT MOTOR ,TRANSFER CASE & TRANSMISSION. 4x4 work great . THE PLYWOOD SIDES HAS BEEN TAKEN DOWN .
Asking $ 4500 or TRADE for DODGE RAM 3500 DUALLY 8.0 Magnum V10 , 5.7 HEMI or 5.9 CUMMINS DIESEL , or other DODGE trucks with Plow. I DO NOT ANSWER E-MAILS, CALL ME or TEXT ME !
Please only call if really interested at show contact info my name is RAY . HABLO ESPANOL & FALO PORTUGUES
http://maine.craigslist.org/cto/5423777703.html
2001 Dodge Ram 2500 V10 with Fisher Plow - $5900 (Rockport)
2001 Dodge Ram 2500 SLT V10 with Fisher 8’ plow,100k miles,leather,power windows and drivers seat,cd player,sliding rear window,body and frame in very good condition overall-a few small rust spots here and there,Gibson headers,needs head gasket.With a little work would make a very strong plow truck.
http://duluth.craigslist.org/cto/5425100975.html
98 Dodge RAM 2500 3/4 ton V10 RWD - $6700
Dodge RAM 2500 two wheel drive Lariat SLT 8 liter V10 3/4 ton club cab pickup with fifth wheel tow package and anti-sway bar addition. 115k plus miles, runs and looks great, tows like a dream. Has been used to pull a 33 foot fifth wheel and you almost don’t know it’s there.
Diamond plate running boards and tool boxes, working AC, great interiror, newly detailed. Kelley Blue Book price is 7,700 used in good shape. Arizona truck , never wintered in MN, title is clear.
http://denver.craigslist.org/cto/5443692760.html
96 dodge ram 2500 v10 - $7500 (Lakewood)
I’m selling my 96 v10 5 speed that is the reason I’m selling it I don’t want a manual truck truck is awsome runs drive shifts great only 120,000 miles witch is nothing for a big 8.0l motor I get about 15 mpg it has a dyno max dual exhaust has 5th wheel hitch on it and has towing package 4x4 works great everything on the truck works great but no heat ac works great. The 8.0 motors are known for the long lasting and hat working motor. Truck is a Laramie SLT truck is stock other then the performance exhaust. Head liner is coming down like every 2nd gen dodge out there but other then that interior is really clean but is messy from my work stuff in there Im really looking to trade the truck for another truck or jeep. I like lifted trucks gas or diesel but cash is king.call text or email me
They sell those mini trucks in PA. Too bad PA doesn’t allow them on the road. Some states do.
http://www.stoltzfusenginerepair.com/japaneseminitrucks.htm
https://sfbay.craigslist.org/nby/cto/5458054215.html
99 Dodge 4x4 v10 ext cab - $3500 (lake county)
4x4 Dodge 99 extra cab v 10 auto Trans 215.xxx miles long bed 3500 obo dash is good seat sucks 17 inch dodge wheels and tires ac doesn’t work I think its a bad switch reg is current clean title get in drive this is not a new truck so don’t expect it motor and Trans work fine no check engine light 4x4 works od works keyless entry works power windows and locks
https://atlanta.craigslist.org/nat/cto/5459188868.html
