V-8 dakota East of Atlanta
1999 DODGE RAM 2500 V10 RUNS GOOD - $3000 (polk county)
Good running Dodge Ram with 197k miles V10 8.0L
Truck is clean inside/out blows ice cold air and heat
Very strong motor and is priced to sell fast! Call or Text show contact info
$3000 firm
1995 Dodge ram 2500 V10 gas plow truck
Selling a 1995 Dodge Ram. $2500 obo. Truck needs a little body work, but the rest is sound.plow brackets need to be put back on
https://lasvegas.craigslist.org/cto/5467815141.html
2500 Dodge Ram V10 Truck 1998 - $8500 (Henderson)
Original owner, garage kept, runs like new. Very low mileage, as it was/is used as an extra vehicle. 2500 3/4 ton quad cab. Sliding back window. Towing. Tinted windows. Alarm system, hooked up to auto door locks. A diamond plate toolbox & side rails along with a black plastic bed liner. Over sized tires/American Racing Wheels. The drivers side back panel does have a dent/scratches because of a brush up against a tree. Otherwise, very clean and WELL MAINTAINED inside too. Non smoker, no odors.
http://phoenix.craigslist.org/evl/pts/5467273117.html
1998 Dodge v10 Engine - $1000 (Springerville, Az)
208,000 miles
Fires right up!
1994 dodge ram 2500 v10 165xxxkm!
Dodge ram 2500
165xxx km!
2wd
V10 magnum
Electric start
Power windows and locks
Has airbags and air compressor
Comes with fifth wheel hitch
Paint is peeling bad like a typical dodge these years
Needs tires
Sterio has loose wire, doesn’t work sometimes
I might have a couple tires I can throw in with the truck
Other then that the truck runs good and is in decent shape
Truck is dirty this is only pic I have of it clean
I could text u more photos
Does not come with tool box
Text for quickest response
5873419666
https://wyoming.craigslist.org/cto/5482923448.html
1998 Dodge Ram 2500 V10 - $3500 (Longmont)
Selling my dodge, Seats need redone in front. Has brand new BFG 33 tires on it. I have put a new transmission on it four years ago, redid the rear end and front end, new radiator, new water pump,new shocks, new 4x4 transfer case, new power steering box, just had truck alignement for new tires. Truck only needs a harmonic balancer put on. I bought a new dodge and selling the 98 .Engine has 180,000 on it. Truck is in Longmont. MAKE ME AN OFFER
http://portland.craigslist.org/wsc/cto/5481347266.html
2000 Dodge 3500 V10 - $13000 (Sweet Home Oregon)
For sale 2000 Dodge 3500 V10. Its in good shape. Need to sale to get out of debt. Its a dually pickup. This truck can pull you threw anything. Need more information call Randy.
http://www.ebay.com/itm/121916296888?rmvSB=true
1998 Dodge Ram 2500 Club Cab Longbed 8L v10 Camper Shell
This is a 1998 Dodge 2500 SLT Longbed with a 8L v10 with a Camper Shell. The truck only has 108244 miles on it. The truck just had a fresh oil change and checkup 44 miles ago. The truck Runs perfect with no issues. No oil leaks other than a small drip from the rear axel bell housing every now and then. The ABS light is on. The Radio, power windows, power locks, Keyless entry AC, Heat and Gauges all work. The tires are almost new. The truck does have some cosmetic issues ( Please Review the Pictures). The Dash has a Crack on top and the drivers side of the truck has damage from hitting a gas pump protection poll. The Camper Shell is also missing a window but still has rubber seal to put a new one in or make one out of Plexiglas… I do have the title in hand. Please buy now or make me an offer.
https://springfield.craigslist.org/cto/5486003181.html
1996 dodge 2500 V10 (springfield)
looking to trade my v10 for a ext cab or 4 door truck of equal ir more power like a cummins or power stroke
http://sandiego.craigslist.org/nsd/cto/5486036632.html
1999 Dodge Ram 2500 v10 - $2000 (San marcos)
Selling my 99 Dodge Ram 2500 v10. The truck is being sold as is. It has some issues but it runs. O2 sensor, wheel speed sensor, cracked radiator, lifter knock. The car needs some TLC and it can be a good vehicle with some money thrown at it I just don’t have the time or money to fix this truck. Tires on the truck are almost brand new. Registration is current and title is clean. 2000obo text preferred 760-685-569six
https://jxn.craigslist.org/cto/5487021755.html
1999 DODGE RAM 2500 4X4 SLT V10 - $5500 (BLISSFIELD)
196k miles clean title V10 auto trans SLT package with power windows power locks power mirrors cruise control aftermarket alloy wheels with new Goodyear Wrangler tires. Pretty clean and solid for the age. $5500
https://quadcities.craigslist.org/pts/5486882983.html
Transfer Case and V10 Dodge magnum - $700
Did a motor swap because tranny went out so selling the engine and trans case, tranny goes with it. Motor runs strong and 4x4 works. 700obo.
http://lexington.craigslist.org/cto/5481854518.html
DID I load this craigs list add right or is there a way too load with less pics ,let me know Thanks
Sure wish I had found the below tractor before I built my 444 international
This tractor is rated near 90 hp on gasoline vs mine at about 50.
Independent pto and both 540 and 1000 speeds.
Duel hydraulics which is a must for most farm work.
The drivers seat is high enough to see over a gasifier if mounted on the front of the tractor .
https://shoals.craigslist.org/grd/5520673129.html
http://www.tractordata.com/farm-tractors/004/6/6/4669-farmall-706.html#
Hasn’t stopped you from buying up every Dakota in Alabama.
He (she?) wants to sell it because it doesn’t idle properly.
https://losangeles.craigslist.org/lac/pts/5512418317.html
