wowzers… Thought the table would have been a lot higher then that considering you are close to the big lake… What kind of bedrock are they hitting? That is a damn deep well… Most around here are arround 90-135ft. Deepest I have ever seen was 305ft.
Dont forget about a rain catchment system… may be too late in the season for that now however…
It is solid rock past about 20-30’. They are hoping to find the water coming through the cracks in the rocks.
you must be thirsty up there with no water. Have you had any snow yet? dropping down into the thirties here next week. Time to start up the wood stove,.
Good luck on the hydrofracking, Bill. My well is 700’ deep and was bone dry a week after it was drilled. After it was hydrofracked, the water is up to the ground level every morning.
Michael: congratulations on finding the one dry column of rock on your entire property! ;D
@BillSchiller I am putting psychic pressure on your water demons to make them give up their hoards.
Decided to set the cabin on 12" diameter concrete posts that are 5’ deep. This way I don’t have to worry about the ground freezing and heaving up the cabin. I had a local sawmill cut three 5" x10" beams 20’ long. The beams stick out 4’ on both sides for a future wrap around deck and porch.
My picture won’t load, I will try again when I get into town
one would think you would need water in the ground to freeze
Touche…Well played, good Sir… Well played indeed.
Hey Bill, Don’t forget ground cloth as a vapor barrier.
Installing solar this weekend.
Today solar will be done. The well company showed up to do some hydrofracking. Looking to exceed the 1 gallon/hr I currently am getting.
That is a cute little place you have there Bill!
Thanks Don. I am enjoying it more every day
It looks like a real “Homestead” except for running water, solar power, metal sod house, and camper for backup.
