you must be thirsty up there with no water. Have you had any snow yet? dropping down into the thirties here next week. Time to start up the wood stove,.
Good luck on the hydrofracking, Bill. My well is 700’ deep and was bone dry a week after it was drilled. After it was hydrofracked, the water is up to the ground level every morning.
Michael: congratulations on finding the one dry column of rock on your entire property! ;D
@BillSchiller I am putting psychic pressure on your water demons to make them give up their hoards.
Decided to set the cabin on 12" diameter concrete posts that are 5’ deep. This way I don’t have to worry about the ground freezing and heaving up the cabin. I had a local sawmill cut three 5" x10" beams 20’ long. The beams stick out 4’ on both sides for a future wrap around deck and porch.
My picture won’t load, I will try again when I get into town
one would think you would need water in the ground to freeze
Touche…Well played, good Sir… Well played indeed.
Hey Bill, Don’t forget ground cloth as a vapor barrier.
Installing solar this weekend.
Today solar will be done. The well company showed up to do some hydrofracking. Looking to exceed the 1 gallon/hr I currently am getting.
That is a cute little place you have there Bill!
Thanks Don. I am enjoying it more every day
It looks like a real “Homestead” except for running water, solar power, metal sod house, and camper for backup.
Hahaha. Yes, I am combining some old and new school together. You forgot to add cell phone, TV and internet.
I feel if I can do all this, then anyone can. We won’t be missing much of the life we had, we just won’t have all the bills. We will maintain responsibility of our energy and heat as well as most of our food.
So a couple of years ago I talked with @SteveUnruh about living off grid someday. His response surprised me but made sense. He suggested to set up “grid lite”.
My thought process when setting up p this place has been based on that response. The property I found is off grid but has been setup as kind of grid lite. I feel if I can afford to setup with some luxuries of living in the city I will.
What I also have done through my planning is to have a plan B and C for as many things as I can. My well is not directly wired to my building. It is wired with a 120 plug. The pump is a soft start so it can be ran with a small generator too. My battery bank can be also charged with a small generator if there is no sun for a couple of days.
Today I had a 250 gallon propane tank placed near the cabin. It will be used for cooking if needed but will use the wood stove when we can. I am also going to install a small garage heater with a thermostat set at 50° to prevent freezing if we’re gone for more than 12 hours.
Everything extra we have can easily be lived without. That part is important to me. Being able to have wood gas to make shaft power will be in place next year. If I had a garage this winter I could implement wood gas sooner. I take comfort in knowing it is available to me.
Moving up north here was an impulsive decision we made this summer and so far I have no regrets. This winter will be a succession of days of learning. It will be the the most trying season of the year.
Looking forward to hear how the winter goes for yah. I am also looking forward to making the drive up there one of these years. Everything sounds great!
