Cody,
Koen posted a link to a spreadsheet for calculating nozzle size a few years ago on the Nozzles for Charcoal Gasifier’s thread at post 50.
Hi Don you can just open your blower isolation valve a little and use the 1/2" valve to fine tune your air for generating load adjustments.
Nice double flute charcoal gasifer and Genset build.
Mr Don , you have done a good job , neat precise workmanship , may it be a pleasure to you.
Don, very inspiring.
I’ve always wished you made more videos. It’s like waiting for Santa
Excellent design and workmanship. You have inspired me again
Fantastic build Don as always , once you have tried what Bob said or you replace the valve for a larger one i would be keen to get your thoughts on the power , of course the flat head are not so great power wise but still be interested in how you feel its working , my attempt was rubbish and i think that’s down to not cooling the gas down enough before going into the engine .
Hi Don , just wondering if you made any progress on your double flute unit yet like a larger air valve , and have you had a chance to run it in a real need situation yet ?
I’m keen to know why you abandoned the split in the nozzle for drilled holes ? i did a ground split in my single nozzle years ago and i found it a lot easier for cleaning away the slag build up and easier lighting too on my large container unit compared to when i had holes drilled in the tube .
Once again i would like to say what a very nice compact system you have created well done Don .
