Duel fuel valve
Over sized mock up of a duel fuel gas control valve for open plenum manifolds or plenum under carb setups.
link http://youtu.be/FrfFTVRIh6E
that’s actually pretty cool… you think you can get them to seal fully?
Arvid hello
Yes I think so. The vacuum should pull the blast plates tight to the main body of the valve.
Nice. That sliding action works like a gate valve and will give excellent results as a air/gas mixer I think. Butterfly valves get a little jumpy. I hope it works out well.
