I’m new to the forum here and I’m getting ready to start on my first gasifier. This project will (hopefully) turn out as both functional and educational, so that I can progress toward building a woodgas powered vehicle. I’ve got the basic plan for what I want for a vehicle already thought up, though I can guarantee it’s not one anybody else has done, and it may not end up being viable, though that is a bridge I’ll get around to burning later. For now I’m setting my sights on a gasifier to power a small engine to turn a generator. I’ve been reading, watching, and learning as much as I could over the last few years in an on and off approach. It’s been so long since I first learned about the principle of a gasifier that I can’t even remember where I first found out about it.
My reason for starting with a small engine gasifier is that I’ve got a large portion of the necessary materials (scrap) already on hand, so it is a great way to cut my teeth without having to invest a lot more than time. As I said above, I’ve been researching them for a while now, but most of the information i have found has been one directional, meaning that I have been able to see what people are putting out there, but I’m unable to dig in and ask questions and get answers about the specifics. This has been the first forum I have found pertaining to gasifiers that has had more than one or two posts over a two year time span.
I come from a background of designing things built from steel, and breaking that design down so that every piece is pre-engineered and designed prior to fabrication. because of this it is hard for me to just jump in and start cutting and welding, because i’ve already got a ton of questions before I’m really started. I’ve been searching for a place where I can post my thoughts and get feedback and maybe a little guidance from the members. I’ve read the information about the site here, and I understand the concept that much of the knowledge here has been learned at the cost of the owner and is not open source. Since I am currently an unpaid member I hope that my questions don’t infringe on policies here, and if they do, I’ll refrain until a time when I am a legitimate supporter. I understand and expect that my build will require adjustments and tweaking as I go, though I have hopes that I can avoid some pitfalls through communication with others. For now, onward with my plans:
I had planned on a build that loosely resembled the FEMA gasifier, though with some additions and changes: It seems that many builds now employ a cyclone style filter followed by a replaceable filter media filter (wood shavings?). I was also thinking that a radiator / fuel cooler would be beneficial, and not difficult to add. i have a lot of questions, such as: location and requirements for an electric blower, intake manifold / carburetor modifications, and a lot more that are escaping me at the moment, but i’m planning on working through my build one stage at a time and handling my issues as they arise. As far as broad strokes go, this is where I am:
Available Fuel: Various species of hardwood: ash, beech, maple, oak; processed by a Wallenstein BX42 chipper.
Engine: Wisconsin-Robin EY21 618cc flat twin (16HP @ 1800RPM) I believe the engine actually may turn 3600RPM, but has a 2:1 gear reduction final drive
Target generator: To be purchased after gasifier and engine completion. ideally the harbor freight 7200w belt driven generator head for $300, but if it turns out to be too aggressive of a choice I will source a smaller unit.
Materials: Various salvaged compressor tanks, hydraulic tank, forced hot air furnace heat exchanger, various new, used, and surplus steel plate, pipe, and structural shapes.
Equipment: MIG, TIG, stick welders, plasma cutter, oxy acetylene torch, mill/drill, lathe, sandblaster, assorted air and hand tools.
I hope to have a rough start on a drawing for the gasifier / reactor unit soon, though my “soon” could be days or weeks, based on what else comes up. Until then I welcome any comments or advice.
