Reading the posts of Dave and Tom above , in answer to the video’s of Mart.
To support their remarks and adding some of my own observations:
Having a correct airflow for startup is imperative to obtain a good quality gas. This would “make or break” your design.
To little flow and your gasifier will not heat up sufficiently to do a proper job (converting all into useable gas, hence no fun )
To much flow and the gas will burn down downstream , generating moister and Co2 but less CO
(due to the amount of oxygen pulled thru the “zone” )
2 important leads already pointed out by Dave and Tom, either use a inflating fan (air matrasses) or a speedcontroller for your kirby.
Where my favorite is the little inflating fan in combination with a pwm and a flare pipe or cooking stove.
Any gasifier build has a 100% capacity (as a maximum before over burning) and a minimum capacity, before the “zone” breaks down ( i consider that at 25% from maximum)
So, running the generator at full load with wide open throttle at max RPM will be tuned in for the 100%
where as no load, at idlle rpm would be the minimum …
Sounds easy ?
far from…
Starting with the minimum load, with small airflow will do the trick… looking carefull at your flare color, once your gasifier settles for a momentary balance (airflow with working conditions) the flame tip color , reddish, should disappear ( meaning, all moister from air and residu’s in the charcoal are getting converted into a certain amount of Hydrogen )
Some charcoal , with more volatiles, will produce some orange and yellow flame tips, which is mostly harmles but works as quality indication. Total yellow or orange flames is indicating to low grade charcoal. My rule of thumb: only blue is good enough
My shortest startup , from ignition to flame, is around 40 seconds.
Able to start the engine about 1 minute after flare, but preferable as the flame is stable…
First little smoke, then ignition with reddish tips,
once the gasifier is at operating temps, and as long i keep it up temperature, the gas is colorless, smokeless and only has a tiny distinct smell.
It will ignite instantly and burn pale - blue.
Once you play with this balance act of your gasifier, generating a constant good quality of gas, you will be able to start your engine from the first spark…
Playing without seeing and understanding your gas quality, is merely a waste of your breath, cranking your engine
( talking with experience here )
My observation about your charcoal quality: looking good as far i could notice your flame color …
Next step to do: follow the advice from Dave or Tom, ad some of your experience , read mine with some sceptisme and enjoy the spinning sound of your engine running…
