Gas temperature effect in Cyclone
Hi, Kevin!
15.4.2021
On behalf of the paperfilter: For controlling the set-up, you need 2 thermometers; you need to control the output temperature of the condensing cooler and the output temperature of the reheating mantel on the cyclone, (just where the dried gas enters the paperfilter). Just to get convinced that the cyclone mantel is performing proper drying of the 100% wet gas from the cooler…
After installation, and getting used to it, you will be able to control the relative temps just by hand, if you have a small hole in the insulations.
Be thorough to avoid ANY airleaks! Otherwise it can become a “fine” bonfire…
Max
Sounds right, my next project with wood gas adaptors, sooner than later hopefully, too many odd jobs too finish for a while .One day at a time i gess though.
