Hi Gary,
The largest engine i have is the 220cc from the Electric generator, the rest is 200cc and 160cc
The check valve is spring-less so no noticeable resistance…
Anyway, this one is a bottom check valve for water suction hose, so difficult to move it somewhere between two hoses
Today i replaced the oil in the tank with rice husk and that worked out fine, barely no more black in the test pad.
If the rice husk is saturated, i will charcoal it and use it as fuel …
Further today i used the exhaust gas return…
it does reduces the heat in the gasifier yes, even at the smallest amounts, but it decrease the power output to much for the water pump… so i had to remove the belt to drive the engine.
Running idle i did hear little difference with or without exhaust, did had to change the airmixture dough to uphold the revs (little more rich)
without exhaust i had to make more lean but both times just a tiny little bit.
Spraying water did however the useable job, revs and power up, a lot… did run the water pump with no problems.
I think i have to make a good setup to obtain a perfect balance between both.
Maybe i will install a pederson plate setup first… and the exhaust return at the minimum level possible…
I am enjoying this so much you know…
The problem i see at this point is finding the right proportion of the charcoal. it does bridge a bit from the friction of the walls ( is only 5" pipe)
tapping the outer walls does the job, but have to find something to prevent that bridging. maybe another reactor with a bit of tapered walls ?
Finding the right materials is the trick here i guess… but i keep looking for a bigger pipe…
anyway, hooked i am, goodbye dynofuel
PS. something the woodgassers not going to like ;-)…
You can not run a gasifier without charcoal
