Look guy’s,
Guess what this is going to be ?
started today from scratch ( or scrap?)
Inside pipe 5 inch
jacked for who knows the future
top and bottom exchangeable
shown the grate, (if i use it)
Can modify to downdraft easy, ( insert from refractory casting Throat and restriction , air trough the jacket nozzles)
but first Gilmore style, updraft trough the cover, top part filled with stainless wool
The stainless cans fit inside the pipe, will be brazed next,…
Bottom part will be with vertical nozzle, easy changeable,..
Tomorow will look for piping suitable for connect to the filter ( cooler and rock filter )
Keep you guys posted
and thanks for the advice
Koen
i added a little drawing, the bottom part ( red,) with the inlet nozzle ( blue ) i would like to make from ceramic or similar
The orange parts are stainless
The black walls are 4 mm strong steel
