Thanks for the info- just reading up on Carbon Black, most of it goes into tyres, so landfilling tyres is actually a carbon sequestration mechanism. I’ll bear the possibilities in mind, but handling the fines is a messy process, and perhaps not the way to stay on good terms with the neighbours.
A nice little breakthrough today- I got the little Kawasaki suitcase, the one that I’d given up on as too puny to get a good gas flow, going on charcoal. It turned out that the hose I was using was too long and narrow, and using much larger (about 40mm ID) was the answer. I managed to get in two 1 1/2 hour runs on about 9 litres of char each, loaded with a 500W halogen floodlight. Details as I remember them- the nozzle was one of the cordierite kiln props mentioned in a previous post- the drawback is poor mechanical strength, and it broke off when I took the tuyere out, so I’ll need to go fishing when everything cools down. Conspicuous by its absence is exhaust gas recirculation- it didn’t like it, at least not the crude lash-up that I tried. I suspect that I hit it lucky, and under all the conditions, it stabilised itself between orange and yellow- around 900C. I did spray a fair bit of water down the tuyere, with a definite change in the engine note- more hydrogen? Starting- I had to prime the gasifier with a fan blowing down the tuyere until I got a stable flare at the engine air intake- after that it started with one pull. The runs finished with the engine just stopping- I was hoping that the exit pipework temperature would give me a clue, but it never rose above about 60C- the water in the jacket stabilised at about 70C. The second photo shows the current gasifier design- outlet pipe on the left, tuyere in the centre, and filler on the right- I’d originally hoped to do everything through one orifice to reduce the amount of gas-tight welding required, but this setup should make filling much easier with less downtime.
One other thing- I mentioned the TLUD stove with the stackable burn pots in another post- I fired it up again after focussing on the tunnel stoves, and got really good results with wood pellets- nice dense pellets of char, very little processing required, not much fines, almost smokeless, and very little operator intervention. To be pursued…
