till now electrode 1,5 mm consum is 5 kg…with a while i learn welding with sticks…
now i have MTC electrodes, those works really fine…before i have had asian stuff, those were not so good, when ignites coatings fall of and stick makes short circuit
the old oil bath filter have had a mouse nest on, and there was a bit rusted through…
also, why not making a new one?
i have not found brewery or distillery stainless sponge in internet, so i think to make them from polyethylene plastic on the turner from a thicker pe -pipe…the same material as i use for my rubber hose connections on the carburettors…this makes really fine long curled chips…cost nothing, simplest way in the outback…
Hi Giorgio, pedal turner? Is it a metal lathe pedal powered?
I’ve only seen wood lathes pedal powered.
As for the plastic, is it the type sturdy water plastic hose (PEM)? If so it whitstands oil pretty good, can be little softer in the beginning, and slightly harder with long use, but not hard/ brittle (just my observations)
hi göran, yes it is originally for metal lathe, prisma guiding, cross support for tools…
i think it is definitely before 1900…upper belt wheel from oak wood, originally with leather belt, round shaped…the original lathe chuck was worn out, so i replaced it…
a very useful engine for me, in his story it was used after metal working from a little home industry from brothers what made grain wind cleaning engines from wood, they have had thirty years ago their sawmill with the energy from a old steam engine…
i use it also for metal drilling, when lathing thicker metal pieces is helpful when my son helps…2 man power…2 mp…energy crisis resistant…
Fantastic machine Giorgio, i like it, total energy independent.
the nozzle, according to eddy ramos calculations has a hole with 16mm…
will see if it keeps up , will also make a protective ash layer around up to the top…
Giorgio, you are an Artist with Metalcrafts!!
Plus, I am sure it will work very well! ![]()
i hope also…and it is not so easy to find always the right vessels, so decided to make by myself…the first models were propane tanks, but for my mobile engines- mowers and tiller, to heavy…so i found milk can for the tiller and harvester mower , a self made bucket for the red mower, a honey container for the motorcultivator…but for the tractor?..so i decided to make by myself…
Saw this on the highway today. It almost feels off topic after your beautifull work Giorgio.
And a tracker on the trailer as well. Very rare, I think.
yes, and the tracker has a steering wheel, how the fiat boghetto model from the ´40 of last century…
would be a nice hobby for your pension time…restoring some old tractors and adding gasifiers…
No me, lots of projects that I am not capable of to finish in this lifetime. Just like woodgas , all my projects evolve way way to slow. Only work and life goes full speed.
Younger people think that when you are in what Giorgio calls your pension time, you would have all the time in the world to do whatever you like. In truth the hours in the day shrink way down. You get up, blink your eyes a couple of times and it’s time for bed again. If you are lucky you can squeeze a little productive time between blinks. Of course I"m talking about the kind of old where you start wondering what grass looks like when you are looking up from underneath it. ![]()
