Library / CFD Carburetor
CFD Analysis of a Mixture Flow in a Producer Gas Carburetor From the article: A specially designed producer gas carburetor is comprehensively analyzed for its mixing performance and response with a CFD modeling. The model is made up of a mixer chamber that has the essential orifices for air and fuel (producer gas) inlets to generate stable stoichiometric mixture at near to ambient conditions using the induction of the engine as the driving pressure differential for the flow, and tested for a case of engine of 25 kWe capacity. The CFD simulations are carried out followed with experimental studies to validate the analysis. The results show a consistency in the experimental data and the modeling has provided a good insight into the flow details and has paved way in optimization in the geometrical design to get a good mixing efficiency. Alternate version: About Us Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. Vestibulum tortor quam, feugiat vitae, ultricies eget, tempor sit amet, ante. Pellentesque habitant morbi tristique senectus. Address Twitter, Inc. 795 Folsom Ave, Suite 600 San Francisco, CA 94107 P: (123) 456-7890
This is a companion discussion topic for the original entry at http://dev.driveonwood.com/library/cfd-carburetor/
