Library / Char Particles
Char Particles Gasification of char particles in packed beds: analysis and results From the article: In this paper a packed bed of char particles is considered for experimental study and analysis. The packed char bed is modelled by extending the single-particle analysis (Dasappa et al., 1994a, Chem. Eng. Sci. 49}2: 223}232. Dasappa et al., 1994b, ¹wenty-,fth Symposium (International) on Combustion, pp. 1619}1628. Dasappa et al., 1998, ¹wenty-seventh Symposium (International) on Combustion, pp. 1335}1342.). All the reactions related to gasi"cation are introduced into the reaction system as in Dasappa et al. (1998). The propagation of the reaction front into the packed char bed against the air stream is modelled. The results are compared with the experimental data on a model quartz reactor using charcoal. Experimental data of propagation of the reaction front through the packed bed from the present study and of Groeneveld's charcoal gasi"er are used for comparison. Using the analysis of Dosanjh et al. 1987 (Combust. Flame 68: 131}142), it is shown that heat loss dominates the heat generation at the quench condition. It is also shown that increasing the oxygen fraction in air has resulted in #ame front to propagate into the char bed. The critical air mass #ux for peak propagation rate in a bed of char is found to be 0.1 kg m s. About Us Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. Vestibulum tortor quam, feugiat vitae, ultricies eget, tempor sit amet, ante. Pellentesque habitant morbi tristique senectus. Address Twitter, Inc. 795 Folsom Ave, Suite 600 San Francisco, CA 94107 P: (123) 456-7890
This is a companion discussion topic for the original entry at http://dev.driveonwood.com/library/char-particles/
