Library / Power from Diesel
On The Estimation Of Power From A Diesel Engine Converted For Gas Operation - A Simple Analysis From the article: In this paper, major factors influencing the power output from a gas engine are utilized to predict the power output from a diesel engine converted to gas operation using various gaseous fuels. The primary factors chosen are the gas calorific value, compression ratio, and molar changes due to combustion; leading to changes in peak pressures, peak temperature, turbo charger pressure and finally the quality of combustion for a given cylinder geometry. Analysis is carried out using empirical relationships available from the literature. Case studies are presented for different fuels to understand these effects on the engine output. About Us Pellentesque habitant morbi tristique senectus et netus et malesuada fames ac turpis egestas. Vestibulum tortor quam, feugiat vitae, ultricies eget, tempor sit amet, ante. Pellentesque habitant morbi tristique senectus. Address Twitter, Inc. 795 Folsom Ave, Suite 600 San Francisco, CA 94107 P: (123) 456-7890
This is a companion discussion topic for the original entry at http://dev.driveonwood.com/library/power-from-diesel/
