Tone I do have two diesel engines here that could be electrical generator capable. The three cylinder Yanmar/950 John Deere tractor. And a water cooled single cylinder Chinese “ChangFa” type engine. Both very, very efficient fuel sippers. And I have the synchronous generator heads I once was going that route. I even every 2 years replenished the 5 gallon can of diesel fuel, giving away the old aged remaining to someone with an older diesel pickup truck
I have been following your conversion work with interest.
A few years ago I decide to go away from rpm-locked synchronous to variable speed&loads engine driven Inverter-generators systems. Here U.S.ofA. these are gasoline/propane engines.
We have two now. Smaller, so not very friendly to wood gas with. And I do not have the woods, or climate to even want to go down the charcoal black-hands road.
The next Inverter-generator will be much larger easily able to woodgas with.
E-V-E-Y-O-N-E should have a series of timed powers out fall back plans.
24 hours. You actually do nothing but enjoy the candle light, battery LED lights. Propane water heat and cook. UNLESS you have household medical electrical needs! You had better have set up a 24 hour battery bank and maintained it! It must be functionable!
Then 24-72 hours. That is were a stored engine fuel generator systems are used. You will need dependable power for on-hands perishable foods and medications.
Past three days and you really into the long term. Then depending on your outside of household obligations; you CAN stay at home; and Operate the needs an aware operator systems.
Crack out, crank up, fire up, the woodgas and charcoal gas systems. Plain facts of it is only you who built these, will understand these. Be able to kick, prod, shake these to keep them producing. Change out a gone-twitchy relay. Clear a clogged valve.
Ha! Just wooden headed, obstinate me. A recent quote wisdom, point of US law, that I wrote down.
“A person cannot ignore the probability that a fact is true.”
