Ok yeah I think the flow has stopped. The water level is not going down very much if at all. So I think the wick maybe a bad idea not sure. I also think the water inlet would be better coming in from the bottom or the side instead of the top.
But that genny has been running for over 2 hours and typically that is all I get on 10 gallons of fuel. Plus I generally need to make an adjustment long before now. Its ran solid this entire run sometimes they do but most of the time they dont. But my batteries were done charging a while ago so there is not much load on it right now.
I guess Ill have to cut the nozzle apart and see whats going in there.
But I do think we are on to something here. These machines are not just charcoal fuel gasifiers they are water fueled machines just as well.
Edit again:: I was just about to shut it down but decided to give a good wack with a hammer and wahlaahh I got flow again.
Yeah I cant make a new post. See new post bellow.
Ok finally video is uploaded.
Ok summery for today. The machine ran a total of 2 hours and 45 minutes. This is very promising as 2 hours if I remember right is about typical. or should I say; was lol. However, it drank the 2 liters within the first hour and 15 minutes. There was a good 45 minutes where it had no flow at all and then at the end after I wacked the nozzle with a hammer I had flow again but only for the remaining 45 minutes. I dont think the nozzle was actually boiling though as the wick was messed up so water was bypassing and just dripping out the vents.
Based on what I saw today I think this unit can process at least 3 ltrs of water if not 4. It ran very strong with the mixer valve at 60% open this is also more than typical. 40% is typical.
Ok so I found some numbers of how much Hydrogen 1 liter of water will produce and the BTU value. This is from the interwebs so dont roast me. But I have come up with this same number over and over again so I think its accurate. 1 liter of waters adds 14,326 BTU’s. So my goal is 4 liters per 10 gallons of fuel and for me 1 gallon is about equal to 1 lbs. So 10 gallons equals 10 lbs of charcoal fuel.
1 lb of charcoal is around 9500 BTU. So 95000 BTU per hopper load.
Total BTU combined if 4 liters of water can be achieved is 152,304 BTU gross. This is not factoring the oxygen to carbon shift. I cant wrap my head around that as the charcoal is part of that number. I bet it adds another 10,000 BTU maybe more?
I cut the nozzle back apart and rebuilt it. Yeah the wick is a no go, it is what clogged up from the rust inside the water tank. I hate saying this but if I go to this jet we will have build some things out of stainless; I really hate stainless steel. But I guess I can justify it as so far this has shown huge promise!!. I also relocated the water inlet to the side instead of on top. I flushed the water tank out and then added a small amount of motor oil. The oil should form on top and coat the walls as the water is consumed. Just dont let it fully empty as I think the oil would carbonize in the nozzle chamber. But that is the fix for the time being.
So tomorrow I will re test and hopefully I wont have any hic ups.
