Well my attempt to once again grow potatoes organically is beginning to fail . . . . again.
Three of my four 42 gallon garbage can growers are blighting.
Only sterilized organic sourced growing media, and certified disease free seed potato’s and still it is happening.
Why? I speculate because we’ve had a nightly air cooling down into the the 36-42F range. Dew point has been at 48F. The daytime 75-85F temps and the general area ground moisture’s are carrying up the fungal spores from around and about. Night air dew-down depositing these then onto the garbage can plant leaves.
The six in-the-ground potato hills are so far unaffected. I speculate that the much greater ground heat-mass is mornings drying these out much quicker. With a much later nightly dew-wetting allowed.
Past experience shows that commercial copper metallic based anti-fungal’s are what is needed here to get spuds to maturity. PITA to have to reapply after every rain, sprinkling, heavy dew wetting. And I do not want the copper accumulating into the limited volume growing cans.
Ha! Ha! So as a failing “science experiment” anyways I am now trying a new-to-me anti-fungal spray.
Dr Earth Final Stop / Disease Control Fungicide
rosemary oil, clove oil, peppermint oil combined at 1.2% of total.
rest “inert” of cargeenum, cellulose, citric acid, citrus plulp, glycerin, vitamin C, water, yeast.
I stem pulled up all of the cell-mushed weakend plants. Doused down still visible unaffected survivors with Dr Earth until dripping wet. Overnight now they have perked right up. Didn’t over-spray kill’en . . . yet.
Of course the real measure will be just what come out of these garbage-can-growers later??
Ha! And this Dr Earth combo kinnda hard on the hands. And REALLY eye stinging with any rub transferring. About like a low percent capsicum spray. Be warned.
IF it works effectively this combo mix could be home grown and made up.
J-I-C Steve Unruh
Hope to make them look after the feed them selfs In winter too. Acorns, chestnuts and jerusalem arthichokes is what l am ameing for.
