Happy Spring everyone!!
Ok so yeah its that time of year again and Ill be picking back up on gasser I was working on last year. However that design will be completely re worked into a new design that I am working on now. The original VersiFire concept with the gas storage is getting scrapped Ill explain more.
So the idea of the versifire was to build a system that could make charcoal, while storing the pyrolysis home apliance usage. The gas produced was moved to storage gasometer to settle and scrubb out tar and debris while making engine grade charcoal. This then evolved to just a gas storage system that ended up with a very complex automation system. The idea was to have versital gas producer that not only supplied engine fuel gas but gas for hot water heaters, gas stoves, gas refridgeration etc and do so with out any tar making its way to the end appliications. However after a lot of consideration Ive decided this machine concept and development has not met design critirias to make the cut to productoin level. So this concept is getting complete scrapped. There are liability issues with home gas distribution as this gas is loaded with carbonmonoxide. There are dangers with storing gas in a tank and the automtion on this machine became extremely complex and finicky as it used its own gas for auto re ignition systems for autonomouse opperation. So this is beyond the end user picking up a wrench and fixing it when things go south. So this development is now discontinued.
Inflation cost plus adopting some stainless steel components have driven up cost to produce the CFX RTR. I have not raised our pricing since Covid. However this year I have had no choice but to re evaluate and adjust the cost but unfortunatly this is now premium level pricing. Although the CFX is now at a premium level of build quality with the new stainless steel parts and also its water cracking performance.
So now to combat this, we simply need a lower cost system to get on the market. (Believe me Ive been trying to do this for a decade; this isnt easy to do at comercial level. These machines have to work)
Last fall I started development work on a brand new charcoal gasifier concept. It has a centralized air feed with direct water boiler. This design worked quite well but unfortunatly the fuel must be highly processed for it to work. So it failed design critieria. So I am going to rework this design and ultimatly it will be run on both wood fuel or charcoal fuel or any combination of the two. Thus allowing it to be Versitile hence re inventing the VersiFire!
2025 VersiFire Design Criteria:
- Must be DIY friendly
*Welders Builder Kit - No Support Systems
*Pre Welded / Un Assembled Base kit - No Support Systems
*Pre Welded / Un Assembled Base kit - With Support Systems
*Fully Assembled Base Gasifier - No Support systems
*Fully Assmbled VersiFire RTR - Ready to Run
Simple Construction Using Off the Shelf Components*Main Shell will use 12 inch diameter Propain and Air Tanks (widely available)*Use minimal manufactured components. Although the majority of the components will be vendor supplied we will need to produce some components that you simply cant buy. But we will keep this to a minimum. Specifically with grate sill and reduction tube we will need to manufacture those items or the user will need to create these parts from scratch. We have CNC machine so its easier for us to make those parts.
Make it Versitile!!!
*Ideally the new VersiFire concept will have the ability to run on either wood fuel or charcoal and of coarse any mixture. If your wood fuel is not making clean gas you can alway mix in some charcoal to give it a boost in temp and also aid with the water shift. Or you may just not have one or the other fuel ready to run but have the alternate available. Good to produce both fuels and use what you have when its ready.
Machine stacking can scale a system easily with a single build platform. You can team multiple VersiFires and feed them into a shared filtration system to a single output.
Based on simalar design work we have done recently I am confident we can build this new system to meet this cryteria 100%. Ill will be working on updating the CAD work on this machine in the next few days and parts are already on order and on the way. So new engine run videos will be coming soon!!
