Allright Bob! Patiently waiting for a flare video!
It seels a glow had channeled to the side of the barrel?
Yes, I’m pretty sure it is a welding pin hole close by. It doesn’t take much to start the char to light up, it loves the big O. I had my suction blower at full throttle to get the 3 foot flame out the gas flare nozzle.
Yes for sure there will be a video.
And as you know once the charcoal is ignited it really doesn’t want to go out
I have had some thoughts about a snuff system, water would be cheapest but that would make a HUGE steam cloud.
Maybe a CO2 or nitrogen bottle
Looking good Bob, you are definitely taking a new path
You are so right, if the charcoal can get air it will burn until it is all gone. I put a ball in the gas out pipe to help the charcoal to smother out. If there are anymore leaks they should show up in the ash trail by the leak. It’s been 18 hours sense I shut it down, I hope when I open the Gasifier unit open all the charcoal is out. I have a spray bottle for just in case.
Cleaned out the Gasifier and found this right at the end of where the hot char lobe ends.
I finally settled on what kind of filters I will be using, thanks to @Til for sharing the Generateur Gohin-Poulenc gasifier filter system.
Looks amazeing Bob! Keep us posted!
Real nice weight saving filter idea Bob. Not to mention will not rust out.
Like like like like… (+100)
I did a little more work on the filter, installed the clycone nozzle in the bucket, and a 3" clean out in the bottom of the barrow. I can still unscrew and remove the nozzle for a complete clean out, but I’m thinking I can just vacuum it out and dump the ash.
THANKS BOB i never quite seen how kristijan had his tolw bag filter mounted.seems like he had too have had some sort of cage too keep bag from closeing together , i know he ran the gas in from the outside of the bag, buy did not see how he mounted bag, or what spesific kind of materiel that worked, And wood the materiel work for wood gasifier allso.
Kevin, you are right, there was a cilindrical mesh cage inside. The material was a normal thick cotton towel.
I thik it shuld work ok with your setup, haveing a condensing hopper. I had tryed it with woodgas too and it worked to a point, it was wet all the time thugh.
Very good documentation Bob
I think the 5 gallon bucket is way too large to get any centrifugal separation at the low gas flows
Maybe hang a 4 to 6” cyclone inside the bucket?
But the filter should get the whole job done and be self cleaning with the pulsation of gas flows while driving
I am impressed
Thank you all for the suggestion, comments, and likes.
Michael, you are right about low air speed spin cyclone, a smaller bucket placed in should help separate dead air from moving air. Need to hook up the shop vacuum and do some testing with fine charcoal.
Kristijan, I like the cotton towel idea, easy to clean out and wash, hope Dana doesn’t mind using the washer and dryer. Ha, ha.
Hi Kevin, with a smaller bucket inside I could still use some other filtering wood medium will have to do more testing thanks for the suggestion.
Thanks Keon, I have not ever had 104 likes before on one thing, coming from you means a lot.
Breakfast and coffee is done, time to get to work on this filter.
A “cyclone” doesn’t need to be cyclone shaped. For 1 inch piping, a cylinder of 4 inch diameter and 12 inch length with a 1 inch hole at the bottom center will create a cyclone shaped swirl of gas and particles. The dust will descend and be carried by the tip of the cyclone through the hole and into the collection chamber. This assumes a tangential inlet near the top of the cylinder and a vertical outlet that descends into the top of the cylinder at least an inch below the inlet.
Thanks Bruce, I might change it more to your sketch if my idea doesn’t work like planned.
Test #1:
Hi Bob,
looks good! I guess the problem with the socks is that you can look through them if hold against the sun (I mean the meshes). And maybe they stretch because of the vacuum. At least my socks would do that
If I remember right, @Jeff noted the same with his sock filter. He has a second fine filter after the sock.
Remember, dust from charcoal gasifiers consists more of fine char and ash and is more grinding in an egine than the soot of woodgas. So you want to filter it as much as possible.
Try a towel or felt. Should work better.
And try to stay at the dry side of filtering. Some parts of the wood ash behaves like burnt lime if getting wet and can clogg a cloth filter. Other parts are soluble in water and can migrate through a wet cloth.
Best filtering effect is acchieved with a dry filter cake on the cloth.
Regards,
Til
Tube socks have the best shape. I only give a dirty sock a little shake to clean them because a dirty sock works better. Never had a problem with moisture, might work better moist. Advantage, dirt cheap at the Dollar Store and ready to go to work after seasoning. The disadvantage is that they are made of the wrong material, stretchy. Someday I will make them, myself, out of a towel. I have no plans to replace the basic design. Like the bucket idea ! ! !
Looling great Bob!
I was just about to say a certain amount of moisture is benefitial for the sack filter to work, as it makes a cake of slightly moist soot/ash on wich more soot collects. When the cake gets too thick, it falls off. There is a picture of that l posted a while back, but cant remember where.
Now, on the other hand, Til is right. Ash contains lime and lye, both are not engine friendly. Specialy aluminium and zink parts.
Edit Jeff beat me to it
I think real woolen socks would work the best , as Gary Gilmore has mentioned woolen blanket material is the way to go and they wash out real easy .
