Third solar tracker
hello ))
dark months are over and i overcome procrastination and did start to build one more tracker.
i would like to share the progress in this thread.
frame construction, parts used and kinematics can be seen in video of the first tracker built 5 years ago.
it is still working and has harvested lots of kilowatt hours.
this is second one, built a year later.
tracker is built mostly from car/tractor/truck parts that can be obtained in scrapyard.
only custom parts to be machined are the worm shafts that work with starter ring gears.
this time instead of truck hub i will use a part from forwarder tractor.
it is basically a big ball bearing and has many mounting holes, some smooth and some threaded. very convenient.
i only heat seated a starter ring gear on it.
car flywheel works fine for altitude adjustment, but it has rather narrow and fine teeth, i will try some big gear instead of flywheel for more contact surface and because i do not have any flywheel at hand. ))
making “cradle” for center tube, it will sit on eight 60207 bearings.
machining contact surface
four M18X2.5 bolts will hold them in place.
making 42mm holes for spherical bearings with grooves for circlips.
progress so far, need to purchase bearings, circlips, bolts to continue.
Very interesting to see your solutions Andris.
I have by the way never seen someone fastening their four jaw chuck in a three jaw chuck before, it has not crossed my mind that it is a possibility
I have also never seen three and four jaw counterweights :slightly_smiling_face:
There must be a lot of used machine tools in your area.
@Johan, @Kent method of clamping equally sized 4 jaw in 3 jaw can be dangerous or even lethal if used recklessly. in best case it leads to round indent in ceiling and shattered chuck. ))
i was not one who did that, but a friend was too lazy to replace jaws and ran unbalanced piece at 380 RPM.
that happened long time ago, but i think, this is same set of jaws. nice set. i am still using them.
regarding tracker, i plan to purchase necessary bits for top side this Friday.
meanwhile i will work on bottom side - must make something that would connect bearing to the pole and hold the worm shaft. cut two plates and now i have to dig some metal, preferably a couple pieces of U profile from under the snow. ))
Yes, I can imagine fastening a chuck in a chuck can be sketchy. When very slow speeds are necessary anyway a shortcut like that could be ok (i.e. big stuff)
A self centering four jaw is probably not ok put in a self centering three jaw chuck like that as they are rarely exactly true but good for most jobs. A new center probably has to be set as ok + ok is less ok.
Not going to be done by me, I only have a three and a four jaw chuck but they are both self-cebtering.
As I said before, interesting to see. Keep up the good work :blush:
update.
gathered some pieces of metal
working with stock metal after pieces like this is a pleasure. ))
but this oddly shaped piece of scrap fits perfectly.
making bearing housings
progress so far
now i only have to drill and tap mounting holes for worm shaft for completing azimuth turn mechanism.
first signs of life ))
working on top side again
donor of thick wall tube - telescopic hydraulic cylinder
it took almost all day to drill six 12mm holes and machine central 135mm hole in the gear.
metal is very hard.
altitude tracking mechanism is working ))
i have doubt that 80 watt 33 RPM motor has enough torque to move 12 solar panels with 53 teeth smaller diameter gear, so i put an angle grinder reducer in between.
48 volt motor is running at 37 volts make one full revolution of the tube in 4 minutes.
next job is to attach rotary encoders on worm shafts for position feedback and solder a control circuit.
What bearing do you use to set everything on?
that is a scrapped part of a forwarder tractor, it held two parts of articulating frame together.
like part 12 on this diagram
a little update
the mount of vertical worm shaft reinforced.
this part has to bear all vertical load in extreme wind conditions and must be sturdy.
by the way this may be useful tool for gasifier builder.
good for smoothing round 40…60mm plasma cut holes.
multiple worn out cut off wheel remains can be packed together and used for grinding.
it makes really nice surface finish.
now the fiddly job of making a controller
gathering parts
PWM signal is used to control the power to motors, amplified by transistors
relays for reversing polarity
i do really like these matrix boards with parallel copper stripes, very convenient.
you can put wire jumpers to connect these stripes where necessary and grind copper off to terminate them,
almost finished control box
assembled all together, did some tests - everything looks promising.
the controller is in “troubleshooting” mode which accelerates the clock and allows the tracker to cycle trough day from waking up to going to sleep in eight minutes.
tracker is controlled only by clock, no sensors are used.
two essential variables are the day since beginning of the year and the minute since midnight.
according to these, micro controller picks the right values in lookup tables (when to start and finish tracking, elevation of the sun at noon) and calculate approximate azimuth and elevation of the sun.
real time clock is running on MCU itself, there is no need for external RTC module.
same interrupt service routine that runs the clock, also runs encoder reading (two position encoders and input encoder) and controls the brushed DC motors.
here is the link to program, it runs on atmega328 @16Mhz only. not portable.
https://www.dropbox.com/scl/fo/y3ed6so097vv5aq824fuq/AP9clP_TtL8_RxX6Kdo9LgY?rlkey=fersngs7x3ztlzkm6x0jb6o5a&st=99bk2nfh&dl=0
The ‘rtc’ functionality on that chip is synthesized it doesn’t have the battery backup which is okay. The external rtc modules I have were like a dollar and use the i2c port.
hello again ))
broken rotary hammer caused a delay in progress.
first, in addition to source code, i would like to add this nano pinout picture.
you can test the program with only I2C display and input encoder connected.
now some pictures of pole and base.
i have no high pressure oxygen/CO2 tanks left, so i used a piece of old crane boom as the pole.
it is satisfying feeling to weld with solar power, not worrying about power company bills.
very satisfying ))
the welder is always set on minimal power, it takes approx 6 kilowatts with 3.2mm electrodes.
attached it to base concrete slab with chemical anchor and M16 threaded rod.
M24x1.5 bolts and nuts for leveling.
forest crane is pretty versatile tool, a good thing to have.
next thing to do is support frames for solar panels, i will use clamps instead of flanges to attach them to the central tube.
some updates ))
attaching clamps to flanges
building load bearing structure from scrap - pieces of truck frame and angle iron
probably not the prettiest thing, but very sturdy and not overly heavy ))
